CAR won't start after POD SWAP
So I originally had a BLITZ Pod filter on and decided to change it to a K&N Pod, and it was driving okay till about 20mins after a spirited run, at a red light it jumps into some sort of limp mode where I can't rev it over 2000Rpm even on Neutral. Had to make it home on 40kms. Engine light came on as well :S
Its a R34 GTT Automatic 98
I have tryed resetting the ECU (battery disconnect) same results.
I then swapped back my BLITZ Pod and now the car won't start at all, could it be my AFM ??
Edited by Jonic
https://www.sau.com.au/forums/topic/468069-car-wont-start-after-pod-swap/
You ask for help and then ignore most suggestions. Work methodically and properly eliminate each potential problem. About every third suggestion is the MAF, Did you actually get a new one? If not try this:
http://skylinefiles.blogspot.co.nz/2009/07/how-to-fix-your-rb-afm.html
and if that doesn't help then check the plug.
I just got my new AFM genuine and nope still same problem what a load of shitz, I tried starting without the AFM and it idles perfectly and with the AFM it readjusted itself and stayed on after I plugged it in while the car was running. Still won't let me go over 2000rpms zz
  • 4 weeks later...
2 hours ago, Jonic said:
It was the coolant temp sensor. Everyone is so clueless lol
Considering you created three threads for issues, don't expect further help with attitude like that. Remember, the people on here helping you are regulars and will remember you.
my apologies to everyone, i did everything you guys told me but i still couldn't diagnose it and got frustrated cause it felt like I was the only one getting this problem on a Skyline and nothing was working. So excuse my attitude if you guys got insulted in anyway. Peace
  • Like 1
    • I mean it's a bit late to say "This won't have any tangible effect and it is not worth spending more than about three seconds on it, please just enjoy the car" But I said it anyway. Does the pod actually get any airflow in that position behind a bumper like that?
    • Hey guys - apologies for digging this up. Has this website been shutdown or is the outage temporary?
    • So, went shopping at Just Jap for things that might work for the intake  After some trial fitting there I ended up with a 3" x 45° silicone bend, a 3" x 300mm alloy straight, and a humped joiner, some minor trimming will be required to shorten some of the stuff, but nothing that is beyond my "ham fisted" skills The guy at Just Jap was most helpful as we had all sorts of joiners,  bends and stuff out trial fitting  Laying it out above the stuff in there it seems everything will fit nicely, and looking at it, it is probably the way I should have been looking at doing it from the beginning, probably..... In the end it is a front bar off job anyway to remove the original stuff behind the front bar that is taking up the required realestate needed, so maybe a Thursday or Friday job And because I'm a hopeless consumer, I grabbed some new steel wheel nuts, the current ones are a spline drive type with a "security" socket, that somehow someone keeps misplacing, the new ones are a basic black steel 17mm hex socket In other news: I just did my "final" tax return, I am now officially a old retired veteran pensioner, and I'm milking the system for all it's worth,  life is good
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
