Need more radiator
I currently have a Cooling Pro Triple Core 40mm from Just Jap, but I need more cooling at the track.
With respect to design, here's my current set of assumptions;
- Number of rows does not make a huge difference
- Number of passes probably makes more difference than number of rows
- Thicker core should be better
So I should probably get something with ~50mm core and two or more passes
Options;
Blitz Racing ZS 42mm, just jap, $600 or rhdjapan $399+delivery
KOYO Copper Radiator Type-S, "Num. of Layers: 2" $436+delivery
TRUST GREDDY TW-R 50mm, "2-Row" rhdjapan, $436+delivery
HPI Radiator Evolve STD Series, 50mm, "Wide Tube 2 Core" rhdjapan $492+delivery
KOYO Type F Aluminum, 48mm, "Num. of Layers: 2" $802+delivery
HPI Multi Flow Evolve, 40mm, "Multi Pitch Core (Triple Turn)" $871+delivery
Does "layers" mean cores or passes? Any recommendations from this list or elsewhere?
https://www.sau.com.au/forums/topic/468413-need-more-radiator/
Yep have oil cooler. Until the last power upgrade, I'd get to about 110 on the factory oil temp gauge, and the coolant temp would stay at half way on the factory gauge. Now coolant gets to 3/4s quickly.
these 2/3 core radiators aren't actually twin or triple pass are they?
Best bet would be to talk to a local radiator shop about making a custom twin pass radiator wouldn't it? Presumably that would mean sideways end tanks but shouldn't be to hard to make work in a skylien
Just the HPI Multi Flow Evolve, but its only 40mm according to RHD.
JJ has its "HPI Evolve" at 50mm, and the add says "Provides 30% Increased Cooling Efficiency".
50mm is probably 30% thicker than a stock core. 50mm is a thick radiator. Generic ebay 50mm core In mine doesn't get hot, or didn't.
End of the day its a trade off, Thicker is better and holds more fluid, more space for air to pass through, but weighs more takes up more space. Twin pass means you have generally more usable area used which is a plus, eg i'd expect that HPI actual twin pass radiator (nice find!) to cool more effectivly than my 50mm normal one... but as i said, would it matter for my usage? no...
If you can afford to drop 750 bucks on a radiator I think you'd go well with the HPI twin pass one, but that's a gut feeling only.
Also - do these things do anything? The bonnet already blocks air from heading over the top doesnt it?
http://justjap.com/engine/cooling/sri-greddy-style-alloy-radiator-cooling-panel-nissan-skyline-gtr-bnr32-black.html
I think cooling panels have an effect. The seal with the bonnet is not that good. SK fitted one to his Stagea early in the piece and he is quite a results orientated person not that much into bling.
They definitely work.  But you have to go the full monty and make sure that the air can't just escape everywhere else.  So that usually means packing the gaps at the sides with closed cell foam and making sure that the undertray/diffuser area isn't open between the intercooler and the radiator.
17 minutes ago, Borci88 said:
The radiators that Racepace sell are triple pass and are about $500.
Looks like their website is dead - i'll message them.
Ok, there's big gaps everywhere.... who sells foam that's up to the job?
Upholstery places, car trimmers? You can get stuff with adhesive for the strips.
If anything just adding foam to the top of the radiator support, if it isn't sealing, will be exactly as effective and much cheaper than one of those cooling panels. Also the SRI ones dont fit over the AC lines.
I'm concerned that generic stuff wont last long with the temperatures and fumes... too paranoid?
Why not PWR? They are the choice of major motorsport teams.
Also how much glycol are you using? The less the better for cooling. You really just want anti-corrosion and some gycol as lubricant.
And adding some panels/shrouding will definitely help.
I used the grey open cell stuff that is often used to pack IT equipment and the like.  Open cell is not as effective, but for pieces that are 2-4" thick and getting squeezed into gaps, it hardly matters.
Self adhesive is only so-so useful.  To get the stuff into the vertical spaces you need to poke and prod it.  It's worth shaping it a bit to fit the obvious profile, but just make it fatter than it needs to be and ram it in so it stays put.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
