Your opinion, more boost or not? RB25DET GTX3076R
G'day guys, I'm after your opinion or anyone that has a similar setup to my car.
Car is a 1998 R33 GTS25T
Current mods
Stock bottom RB25det, compression 150 - 160 across all 6.
Stock head gasket
ARP head studs
upgraded valve springs
camtech 272 9mm cams
Haltech plat pro
wideband kit
3 bar map sensor
6boost t3 twin scroll manifold
garrett gtx3076r .83 twin scroll, 50mm external gate
Walbro 460 e85 intank fuel pump
Currently making
336rwkw @ 19psi low boost
360rwkw @ 25psi high boost
United E85 fuel
Before i go and speak to my tuner i wanted to ask you guys....
Has anyone thrown in more boost with a similar setup? Should i leave it where it is? looking at turning it up to 28-29psi to hopefully crack 400rwkw or close to.
Cheers.
360rwkw sounds pretty good but more may be possible. I would just ask the tuner to keep increasing boost until
1. EGTs get too high or
2. detonation approaches or
3. It stops making more power.
I've had that setup on a RB28. Yes it can make 400 at that boost.
Just leave it as it is, man. It won't really make the car any faster in 97.7% of scenarios. Why tempt fate? I'd go as far to say as leave it on 19psi with a stock gasket. Twin scroll housings and manifold should make it a pretty potent setup.
Source: Tempted fate.
  • Like 2
Well to put it into perspective, you gained an extra 24kw by bumping it up an extra 6psi. You now want to make it crack 400kw, an extra 40kw by only going up another 4-5psi.
Logically that ain't gonna happen if the tune was done well in the first place. Can always give it a go and it might happen, but I think its optimistic.
  • Like 1
I wouldn't be going past 25psi, typically stock rings are not meant for such high cylinder pressures. Especially in an engine known to have ring land issues In theory you would no want the rings to touch and compress on one another. I'd be looking at other items rather than boost pressure to hit 500hp.
In my RB20 this year I did about 12 runs in a weekend at our local strip. I was upping boost constantly and ran a 10.67 twice with 25psi @ 131mph and 27psi @ 133mph (Different 60 foots). I then proceeded to run 29psi and 30psi. The engine still works "fine" and is fully standard stock internals, however it has a fair amount of blow by and I suspect piston failure due to cylinder pressures.
Thanks for your input guys. Another question for you...........
Closed loop vs open loop boost control
Since i use a haltech platinum pro ECU, is it better to control the boost pressure going through this ECU instead of using a EBC? Currently running off a Greddy ProfecB Spec II, which in my opinion doesn't feel like it is setup properly. What is better?
Cheers.
Wow that look's great. Right i knew this was the right way to go when i got the work done. So correct me if i'm wrong, If im using a EBC such as the profecB II. What is the use of the 3 bar map sensor i purchased with the Haltech ECU? Is it only used if i run the boost through the haltech?
Actually, the Profec has a MAC valve and the ECU could just as easily control that as any other.
OP.  The Profec has its own MAP sensor built in, which is how it knows what the manifold pressure is.  Not that it matters, because these boost controllers ARE NOT CLOSED LOOP.  They do not try to keep the boost in the plenum at a fixed value.  They just run the bleed valve at a pulsed duty cycle that is fixed when you set it up and for all time afterwards.  The boost measured by the Profec is just displayed on the front of it so you know how much you're running and so you can set it up.
If you use the ECU for boost control, then the ECU knows what the manifold pressure is from the 3 bar sensor you connected to it.
Edited by GTSBoy
  • Like 1
Add more boost.. ring lands won't blow if you limit torque. Also spray more fuel at peak torque to keep the cylinder temperatures down and pump in more timing as torque decays..
I think the excess cylinder temps cause the rings to expand then smash the ring lands not so much the pressure/force.
Because you even hear of people smashing ring lands with cars making 250kW.
To put things into perspective, I've been thrashing the shit out of my car with about 1.8bar through the motor on the track and it's yet to go boom LOL... but like I said, I run very low timing at peak torque and spray heaps of fuel to the point it is about to misfire... but, the car is happy and the only thing that has died is the stock 300 000km head gasket and the turbo's arse end exploding.
  • Like 2
Thanks guys for all the info! ...  Has anyone had any experience controlling boost through a Haltech platinum pro ecu? Is boost more responsive & steady this way instead of using a EBC? I'm reading on other forums that haltech's inbuilt boost control is somewhat not accurate or tends to spike/overboost...
Good point, progressive timing and rich fuel definitely helped my RB stay together for as long as it has. Heat is definitely the culprit in ring compression / failure, but the quickest way to heat is often cylinder pressure ( Boost, compression, nitrous, etc.) assuming everything else is fine?
More Air = More Fuel = More Pressure = More Heat, I think i'd be right in saying that.
1.8bar would be relative to the amount of flow, what turbo are you running?
I'm running  (well was) the Hypergear SS2 with the ceramic BB centre, happen to be a prototype turbo too lol.. probably why it exploded when I ran stupid amounts of boost through it. The funny thing was it kept making power, so I kept adding boost.
You can control boost via the Halaltech very well if you've setup the base duty vs. boost target table correctly then enable the closed loop. I've done this on 2x cars already and boost control is fantastic. Of course there are a few tricks but a decent tuner should know what to do in terms of boost oscillation etc. but that costs dyno time, which workshops cbf spending time on.
+1 re: Haltech boost control (and Johnny's settings).
Really does work pretty damn well, unless you do weird shit like have an auto with a gate after the turbine wheel and load it up a hill. But that isn't Haltech's fault and it works really damn well, though I would wager most modern ECU's will. To be fair, I'd also say a standalone EBC can be setup to work just as well when you think about it, you shouldn't need to swap ECU's merely for the sake of boost control unless you want fancy things like Boost by gear, or Boost by XYZ variable that the EBC cannot provide.
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
