Bringing a GTT back to glory
Hey guys, this is a current work in progress
let me flood you with the details
Pictured, how i bought this car 2 years ago, paints f**ked, gt wing, crystal tailights.
my reason for even looking at this car was of how early it was imported.
having a compliance date in 2002 and being a 1998 model i knew rust would be minimal, after inspection i was right, not a spec anywhere!
chassis rails unmarked aswell, factory manual turbo,
Those f**king tailights, (shudders)
Since the motor was healthy besides a stuffed IACV, i fixed that and got straight to the cosmetics.
new oem lights sorted,
Some Miesters 18x9 +30 and 18x10 +30
i had ready for the car and an east bear front lip i scored from a wrecker who was unaware what it was!
At least now it was starting to look less like it was ready to go the tip.
From what i could tell, the car was never polished or cleaned, after days on days of Clay bar, buffing and waxing
majority of the car came up great
- Mirrors had to be painted
- drivers rear skirt has to be painted
- front and rear bumper needed resprays
- boot lid had been warped from the gt wing
- driver door has a big bend from being opened against a pole
All pic's after paint repairs and detailing
from here i moved onto some interior bits
led light conversion to white, also have done air con controls to match, and im assuming the original cabin filter. has been replaced straight away
old butchered wiring, then my fitted pioneer double din, From here i moved onto my custom flush gauge install
factory gauges, with then without factory cover, then seperated
then the aftermarket Shadow gauges, Split the lense and bezels
the aftermarket gauges basically pressure fit in to the factory housing, i really dig the look without the bezel
After the gauges were mounted, i tapped into power, acc and earth from the original harness, ordered a brand new clear face from nissan
and here you have the finished result! Also, had the gauge surround, air con and vent painted satin black. very easy to keep clean!
Back to the outside, trying to find a body kit that doesn't look cheap or ruin the car was quite hard, eventually i decided on the east bear rear bumper
all i can say is east bear is worth the money, 100% perfect fit, no modding needed and very strong fibreglass, so happy with the purchase
This is factory
East bear fitted without pods, also note late model nissan badge!
with rear pods
thats all for my first post, more updates very soon :)
Edited by stump_69
  • Like 5
https://www.sau.com.au/forums/topic/468815-bringing-a-gtt-back-to-glory/
I actually really like what you've done here. Such a nice stealthy factory look.
Looking forward for more updates. Certainly looks like you have a nice 34 in your hands.
  • Like 1
On 1/27/2017 at 6:51 AM, Brett Musolino said:
I'm currently in the process of changing my gauges, looks like I'll have to do all three at once
Definitely would do all three together!
12 hours ago, GH05T said:
good work.
how did the paint hold to the plastic. that r34 soft plastic shit is a nightmare once it starts to go bad.
sacrifice some rags and use thinners, comes off very easily.
then primed and painted off the gun, so easy to take care off now
8 hours ago, Jordy32 said:
Looks great, did you get the rear bumper from japan?
 Yeah all the east bear products i have, besides the front lip have been from Rhd japan
not cheap, takes ages to get here. but absolutely perfect fit and finish
  • Like 1
Next up!
More GTR influence, got a factory foglight from nissan, wired into tidy hidden switch
Wired up some Leds to work like gtr valet lights
Some color coded v spec extensions, screwed straight to factory skirts
A gtr rep wing was next, i sourced a factory blade, but im still not happy with the finish
will be getting a genuine one in the future
All painted!
Cosmetics coming along nicely :)
still more to come!
And some nice interior finishers
Gtr Gauge Bezel, was annoyed i couldnt make a gtr cluster work :(
Brand new center trims, leather boot and cig lighter from jesse streeter, hes the way to go for new nissan items!
And a brand new oem gear knob
More to come!
Edited by stump_69
  • Like 4
Next up!
All painted!
Cosmetics coming along nicely [emoji4]
still more to come!
Gtr Gauge Bezel, was annoyed i couldnt make a gtr cluster work [emoji20]
More to come!
Hey mate awsome car looking really really nice good on ya. Keep the updates comming.
47 minutes ago, Brett Musolino said:
Loving this thread! The lip you put on your stock front bar, is it just from eBay? And was there much adjusting to do to make it fit?
Its from rhd japan
Its a east bear front lip
  • Like 1
  • 1 month later...
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
