Racepace R33/R34 GTR Catch Can/Washer Bottle with inbuilt Oil/Air Separator
Hi Guys,
I have a Racepace R33/R34 GTR Catch Can/Washer Bottle with inbuilt Oil/Air Separator for sale. This came out of my R34 GTR and was working perfectly but needs to go now as I have to fabricate a new one to suit the new engine setup.
The great thing about Racepace catch can's over normal ones is they have a built in oil/air separator which means you can have it leading back into your intake without having to worry about sucking oil back through.It also means you end up with one clean looking unit rather than the usual style oil air separator you see on top of the engine covers.
I had this one specially made with -12 AN fittings rather than push on style hoses as it looks a lot nicer. You have 3x -12 fittings for breathing (rockers, sump etc) and a -6 drain.
Overall its in good condition just a little bit dirty. No marks or scratches. Cost me $450 new.
Price is $300 ONO and catch can is located in Rouse Hill, NSW. Pickup is preffered over post but will post at buyers expense. Any questions just message me or sms/call 0403858714.
Thanks,
Brett
  • 9 months later...
My catch can drain plug is a pain to undo and empty, it just pisses out and hard to stop it.Now there is a servo with E85 it fills up pretty quickly.
I was hoping to pump it out from the top but it looks like there are baffles where the lines come in on top, I do not want to stuff it and I do not know the configuration of the baffles and just do not want to drill through them :/
Any suggestions ??
2 hours ago, reaper said:
Put a line on the spot where the drain plug is an extend it to under the car, that way you can just open it and dump it into a container which is how mine is setup.
Do not understand exactly what you mean, got a pic ?
I was thinking that I will have to have the catch can taken out to do it properly. Use a butterfly tap , attach a hose to it, with the hose going low enough to miss all the other parts so I can put a container under it.
There is no room to do anything where the drain plug is , I made a funnel with a long hose to drain it , but hard to catch it all when the plug comes out and shit went everywhere , I did catch most of it but, yuk!
image.thumb.png.163a88e7968b947270d8159a94470d99.pngthe drain plug is in a situation were it is hard to undo without it going everywhere as you cannot get anything under it , I will have to have it pulled and and do as you suggest,
Would have been easier if the drain hole was not just about flush :(
Edited by Nismo 3.2ish
spelling
  • Haha 1
made up a hose and chopped up a milk carton , some thin aluminium and joined them all to make a funnel. The milk carton is pliable and can be sort of molded around the drain hole and it worked pretty good and only a few drips got away, next time I will put a tissue under it and all good
  • Like 1
 Share
    • that is correct to be more precise, this sensor goes to a loom which contains only the flat blade single terminal (to connected to this sensor) and then the connector shown in my first post. This loom is tied up to one of engine hairness
    • This is really sad news to hear and it has taken me a few days to come to grips with the loss of Neil.  Neil was very straight forward and I have always respected his honesty and how he called it how it was.  He was a very knowledgeable man and was always available to provide advice when you needed help to solve a problem because he would have encountered the same issue in the past and could explain how he solved it.  Neil will be missed by many members of the Skyline family.
    • Dropped the car down to my mates shop on the 19th to get it on the dyno. Ran the motor in and dropped the running in oil and filter and filled it up with some engine oil.  Monday arvo I went down and we got a tune in her. Had a fun time trying to get it to hook up on the rollers. We end up having to roll into the throttle, reaching full throttle at around 6k. Made 23psi on gate then tapered off to 20psi up the top and spat out a healthy 700rwhp.  We had a slight voltage issue which was dropping ecu volts to around 11.8v so we called it quits and on Tuesday I went down and ran a couple of new power feeds to the ECU and DBW relays. Have yet to test it as we were trying to get things sent into the ECU from the TCU over CAN. We've now got oil temp, programme switch and gear position. Still working on gearbox speed, but have been told what to do so hopefully that will sort it. Once we've got speed working, we can start setting up the gear shift cuts and do some clutch adaptations in the TCU.  Should have the majority of it setup this week and go over the tune to see how it is now with the new power wire.  Was slack this time, didnt get any full runs as I was watching the TCU data on the laptop. Snapchat-322660241.mp4
    • Not until I googled it, now I remember lol. Seems like it's just to clean it up. But it doesn't stop the leak, I have a leak issue though? Thinking whether I need a new bottle, surely not lol.
