Sorry, I should add, your alignment should be reasonably correct before you test it because it can make e big difference to the geometry. Camber can tuck the wheel inside the guard at full compression, caster can cause clearance issues to the front bar, correct individual and total toe can affect wheel location at full lock etc etc
Well bloody hell that all sounds like a lot of work.
I know it "had" about 8deg of castor in it and it "Had" -3.5 camber but the camber especially will be out now with extended LCAs (I left the lock stops off also...)
What did you mean by "Obviously you've dealt with the inner shoulder on control arm already"
I found it hard with the tubs to fit everything where it was accessible and took a lot of time to fit things for ease of maintenance. My priority was keeping as many things between the chassis rails & behind the rad support for that off chance of contact with objects.
Realistically when is the car going to be at full lock? you won't be running guard liners and trimming bottom of skid skirt and front bar to fit is normal.
Have a look at Sams s13
No photo description available.No photo description available.
https://www.facebook.com/SamCollinsMotorsport/photos
I went with kelway tubs as heaps easier to fit than the other kits.
Welcome to building/working on proper race cars 😂
Wait til you need help running it, need some good mates that like to be at the track to help......
  • Like 1
I was being precious too about drilling & cutting into the tubs. Powersteer res is behind PAS headlight and both relay/fuse boxes are mounted on rad support, overflow mounted off strut tower in front of BMC.
only thing not in there is the oil filter which is remote mounted to chassis rail clear of the front right wheel
Edited by robbo_rb180
this ...
best and worst bit of pushing your car further and further !
this wasmine a long while ago now + oil remote has always been on drivers side outside the engine bay
  • Like 1
Yeah I have no issues with that side of it, it's more about do I need it/will it be a benefit as it's a fair body of work.
On 8/5/2022 at 9:51 AM, bcozican said:
this ...
How big are your wheels? Did you "need" tubs or did you just get them like I did because you thought you would lol
I actually bought this shell off a mate who was building this as a drift car thats why they where their in the first place
Now im glad they are there because im at 18 x 10.5 - zero with 295/35/18 tyres
I think the tubs actually only need to be half tubs / cut diagonal from strut - as regardless of how big wheel is it wont hit where it goes to at the front of the tub and also it would provide more room in the bay
I agree, but cutting through an angle would be very fiddly and probs require more material than I have here to work with.
The Kelway ones kinda take this into account a little.
The slicks are only 270s but I can run p to a 295 for WTAC based on weight, but that might be pushing it on a 10"
Your guards would be bigger than mine too, so maybe I do need ot just bite the bullet and slam'em in.
On 8/5/2022 at 10:16 AM, bcozican said:
# carbon 😆
but yes always a compromise
Other might have a diff opinion but Ive tried a 295/30 on a 10" was squishy, rolling mess through cornering didnt like
I think 10" is the minimum so I'm not surprised.
this ...
Yeah a mate has found that out wit his r35, needs 2 people to just to run it for a basic test day.
Bite the bullet get wider guards, Kmak aero is a lot better quality than the "jap" stuff thats made overseas.
If goal is to run a 295 eventually tub it. Do it once and be ready for future, engine is still a while off..
Surprised you haven't just snapped this up
https://www.facebook.com/groups/1597445057169847/permalink/3134510930129911/?sale_post_id=3134510930129911
We've already discussed this "as a team" as NCR is 3 of us, my build is just most active at the moment but there's an RB30 R33 @BrendanR33 and a Weekend warrior 370z guy.
the 295 comment is really about having to run semis for WTAC or any other event that requires it.
I didn't think I "needed" wider guards up front, but the rear is looking very likely thought I could get away with those 50mm flares that I said I hated the look of lol
  • Like 1
lol looks like wrong thread, I've got a short attention span.
you should be able to tell as soon as you bolt the wheel with tyre on if you are going to hit the strut
yeah that looks pretty good, current kit is complete so just run with it.
Its hard buying/sharing a car with people, I was almost going to get in on a production car but wasn't really going to work out when came time to sell my share.
And then theres the issue if someone bins it......
  • Like 1
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
