Electric Turbo
Interested to see this:
The use of a 48V system also allows engineers to fit on an electric auxiliary turbocharger (eZV)  that could spin up to 70,000rpm within 0.3 seconds to deliver an immediate throttle response and zero lag.
Full article:  https://www.carsguide.com.au/car-news/next-gen-mercedes-engines-bring-48v-electrics-and-the-return-of-the-straight-six-46903?utm_source=taboola&utm_medium=msn-australia&utm_campaign=taboola_alwayson_desktop
and how long will it be before we start tearing out our exhaust gas energy turbines and installing a 48v electric one?  It could be a game changer.
https://www.sau.com.au/forums/topic/470167-mercedes-electric-turbo/
I remember reading something about an Audi (that's already in production) using a one - but to spool up a conventional large turbo; I think it's a great idea and good approach to use both technologies together until electric just takes over replacing the entire power plant.
This will be a version of the formula 1 hybrid technology. Turbo is still a turbo but uses an electric motor to assist. And it sounds like effectively a generator/motor harvesting electricity and deploying it when required
If you havent already, check out formula 1's V6 hybrid engines
I'm actually working on an engine equipped with one. The engine is still being installed in the engine bench as of now. We won't test the electric turbocharger before long.
These turbos need to be cooled via the engine coolant or via a low temperature circuit, and with the power cables, the plumbing etc... and the fact that they're small unit for now only aimed at spooling small turbo they're still very far from being properly sized for our kind of engine/usage.
But some manufacturers are working on 12v variant of these babies, you just need big ass wires to feed them. And we still need a control unit or an aftermarket ECU which can control them, an heavy battery to take the shot when the turbo kicks in and a powerful alternator.
Way too much modifications for now to be worthwhile but 10 years from now who knows ?
  • Like 2
I got 3.8psi out of a 12V system running on a RB25det engine with a electric turbo that I designed for a Chinese company in 2011. There are way better motors today I think I can get it to make around 7psi if I'm doing it all over again this year. Boost was instant spinning up a T04Z compressor once activated. I guess it can be attached to a turbine shaft to make it hybrid. Just don't know whats the reliability of the electric motor on long run.
  • Like 1
super keen to know how you go with the next round of testing....  hope you test it on the torque black hole- rb20det :-)
Cheers
J.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
