14 hours ago, TimmyMA70 said:
I'm a fitter/machinist Dan. I have helped other people out previously with different projects along the way. I love helping people, however the biggest reward is the ones who truly and genuinely appreciate your time.
The last guy I helped I realised the extra cash is just a sweetner, as unfortunately the appreciation was more of an expectation... I struggled alot with motivation.
However the guys who give good feedback, it honesty wouldn't worry me if I got paid or not lol
Thanks for the feedback and compliments as usual mate ?
OK so as long as I'm really appreciative you will come to my place and finish my car, sounds good. Hell I'll eveb fly you down here ;)
Quality makes sense given profession.
11 hours ago, Burger said:
"12 Primera Street" I see what you did there.
You like that? ?
Sounds good to me man! Lets make it happen ?
I've always been interested in custom car fabrication/sheet metal work etc since I was an apprentice. Did an advanced welding course to learn some more about tig welding and the sheet metal, I just make up as I go along.
6 hours ago, ActionDan said:
Maybe I can have SAU build my car.
Timmy can build and fab, @Dose Pipe Sutututu can tune it, and we can do a GoFundMe to pay for it all lol
Oh shit! Here we go. It's happening ?
You get a free car build, you get a free car build and you and you ??
Never thought of a gofundme for something so important! ?
6 hours ago, Dose Pipe Sutututu said:
and while we at it, we can fund the tuner (me) a F30 335i M-Sport with a factory LSD lol...
I will contribute to that a fund a built R33
While we're all in the giving mood! Why not?
Yeah it works well, I give my R33 to the fund, somehow someone trades/strips/sells that and turns that into a BMW for me, and i"ll tune the car, and you get paid for fab work :)
All the extra cash can go into our pockets.. what an idea, just as good as that LMCT plus site!
What could possibly go wrong!?
Very minor update.
It drives. Drove it approx 10m out the back to give it a wash.
Still a few things to sort out, like rusty rotors, ordered the rest of my exhaust components today, a dual flow meter setup for my tig regulator so I can back purge this exhaust, double check everything and off to get a tune.
Thanks for reading ?
  • Like 1
Dyno when?
I'd like to say early November. I've got a weeks holiday coming up, so unfortunately there won't be any progress then as we're going away.
I'd estimate 3 or 4 days to make the exhaust, back purging everything as I go, including modifying the engine crossmember for clearance.
Another few hours in a wheel alignment (currently in track setup) too before I trailer it down there, so then I can drive it home once finished.
4 minutes ago, ActionDan said:
Which page/post has the negine specs so I can review first lol
Oh and what dyno does he run.
This engine is a stock P12 SR20VE. Stock cams, stock head, springs etc. Stock bottom end. However has been shimmed to 0.01mm factory specs.
Engine is only running the alternator, no P/S pump, water pump or A/C
4-1 to 3" collector headers
3.5" - 3" mafless intake pipe
Haltech Elite 1500
That's basically it man.
This is basically an interim engine, partially to make the car more enjoyable for me and so I can teach the wife (or she can teach me) how to drive on the track lol.
Then I'll finish off the P11 engine.
Jez uses a Mainline Dyno from memory.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
