17 hours ago, Spec-s Gttt said:
Call this guys up dude they pretty good tune cars and mods speak to sam
From what you've posted appears to be a graphics mob, a car audio installer and a panelbeater? Where does tuning fit into it?
1 hour ago, AC34GTT said:
Anyone have experience with Race Pace in Bayswater?
Yes, a forum favourite. Did fantastic work installing some tricky mods and tuning my GTS-T with a very safe and "factory" feeling tune - would happily re-use.
I've nothing but good things to say about Racepace. Although, I will admit they aren't the cheapest around, but at least you know it will be done right the first time. (In my experience).
Good to know! Now I've gotta decide between Racepace and Chequered!
On 05/06/2017 at 3:55 PM, AC34GTT said:
I've heard nothing but good things about Chequered Tuning. But they are an hour each way from where I live...
May I ask what work you had done at Chasers? Just tuning?
Car was stock originally - They installed power fc, PFC boost controller, injectors, fuel pump, and high flow, then tune.
  • 4 weeks later...
Finally got my r33 gtst tuned at chequered.
Car made 258rwkw at 17-18 psi peaking to around 20psi in the midrange.
Hks gtrs turbo, blitz return flow cooler, good 3 inch exhaust, 1000cc xpurts and other supporting mods.
Car now makes full boost at 3500rpm in comparison to full boost at 5000rpm it made with the OP6 hypergear highflow at chasers.
  • Like 1
  • 3 weeks later...
On 6/8/2017 at 9:44 PM, vxsr33 said:
Personally I've been to chasers for a tune and i wasn't too happy with the outcome. At the time i had a hypergear g3 r34 highflow turbo on my r33 gtst, blitz return flow cooler, full exhaust and all supporting mods.
I was happy with the power of 250rwkw at 16psi, what i wasn't happy with was the fact the car was making full boost at 5000rpm.
When i saw the dyno sheet i had a chat to paul the tuner about why it was so laggy and he basically just told me it's the turbo and he can't do anything about it.
Even though i had a return flow cooler, exhaust was a bit restrictive (wasn't too bad though) and the bigger turbo i don't think i should have been reaching full boost no where near that late. I wasn't happy to not get any suggestions or solutions other than to get another turbo.
Not trying to bag chasers out or anything just sharing my experience, heaps of other people have been very happy with their service. Other than that the car felt way smoother to drive, idled perfectly, cold start was perfect aswell.
Imo if you have a hypergear turbo go to chequered since they deal with hypergear all the time.
Can't blame the tuner if you bought a shit turbo and have a less than healthy engine.
Much better choice of turbo!
Sounds like the tune was fine on the previous setup but the slightly tired old RB25 is letting you down a bit. As long as it drives good power is irrelevant.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
