s13gtr AWD S13
  1. Gday guys,
Here is my s13 i have been playing around with for the past few years, started out as a cheap drifta but got bitten by the drag racing bug and have chased that path for a while, but i still want the car universal as i want to do local circuit and motorkhana days. I have been slowing increasing the power, increasing turbo sizes from gtx3076-gtx3582-gtx4088-gtx4202 to currently having precision 7675. As i made more and more power it was getting hard to put it down so i was searching for a R32gtr and then they became unaffordable for me so i bit the bullet and went AWD on the s13. Slowly gathering parts for the conversion, i didnt want to commit until i had everything.Tinkering away in the shed i got my hands on a frontcut for dummy assembly, once i was happy with engine position i just started stripping my car apart and threw it in... (well not that easy.... but it works!) anyway here is a few pics of the cars journey.
rb25/30 built by Matt Sims Performance
PPG H dogbox
Precicion 7675 turbo
haltech elite 2500
ets pro awd controller
  • Like 8
https://www.sau.com.au/forums/topic/470754-s13gtr-awd-s13/
16 hours ago, IT15ON said:
Awesome project. I recently put a gtr rear diff in my S13 and wondered how the front one might fit too, what sort of times has it run?
I have only raced it at MOTIVE Drag Battle at Cootamundra as i havent finished getting the car ANDRA teched yet. We were chasing some lost boost problems, finally found what caused it and snapped the mainshaft in the gearbox as i grabbed 2nd gear on the next pass. As the DVD isnt out yet i cant really say how fast i went.
  • Like 1
https://www.sau.com.au/forums/topic/470754-s13gtr-awd-s13/#findComment-7833294
17 hours ago, ActionDan said:
So what sump did you use and is this RB25 (Stagea) AWD gear or GTR AWD gear? Unbody shots plz
all r32 gtr gear, baffled gtr sump. haven't got any underbody pics, ill try remember to get some next time its on the hoist. rather drive it atm than have it on the hoist.
heres a couple of pics i had on my phone, probably what you want to see anyway
included one of the shortened gearbox mainshaft from drag battle
  • Like 4
https://www.sau.com.au/forums/topic/470754-s13gtr-awd-s13/#findComment-7834770
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
