Brendons M35 build
Thought I'd create a mini build thread on my progress with my first foray into Nissan wagon life and also a place to ask questions/path to follow.
I bought the car with f**ked coil packs so I picked it up cheap off some Indian guy. Put a new set of coil packs in and all was sweet for the next 6 months . . .
https://imageshack.com/i/pnV0vOWcj
https://imageshack.com/i/pltD8QHij
https://imageshack.com/i/popQVxMsj
I noticed an oil leak from the passenger side that was slowly getting worse and traced it back to the oil feed line. Ah well no biggy, just an easy fix or so I thought! Having not worked on a VQ before, it wasn't until later on I discovered you can't get the line off without pulling the whole turbo :down: Since the car wasn't far off 200k and the turbo had begun the Dyson whine song, I frantically searched for a new turbo. Scotty to the rescue with a Billet Intense he had spare that got to me in 4 days.
In the mean time while the car was off the road I set about fabbing up a 3" bellmouth dump pipe.
Then followed it up with a 3"-2.5" intake pipe. (Still need to weld on BOV return bung)
And this weekend just gone I fabbed up a 3" catless exhaust system to finish it all off. I picked up 7psi of boost without touching a thing, so it's stuck on 21psi with standard injectors and pump. I've hit up Christian to see if it's possible to run the car safely at this level on 98 with his flash tune, otherwise I will probably put a hi-flow cat in to drop the boost a little.
I've got a few other things in the works but all in due time!:10_wink:
Edited by Sack87
Pics not working
  • Like 8
https://www.sau.com.au/forums/topic/471232-brendons-m35-build/
Productive day trying out my my new pipe bender. Made up a rear subframe brace to help reduce some flex because the factory welds back there horrid. :2_grimacing:
I plan on making a few more of these up, so watch this space if you're interested in one:1311_thumbsup_tone2:
  • Like 5
You can buy a brand new one from Nissan for around $100 but your looks solid and nice welding.
Replaced the headlight globes last weekend with some LED Nighteye ones off eBay.
Fixed the dodgy wiring job obviously done by the compliance shop and also fixed the issue with the passenger side globe constantly dropping out. The H1 globes earth through the clip into the light body but the clip had been bent and contact was poor. The LED globes have earth through the harness, so crimped on some plugs and walla!
They just fit in behind the cover luckily and beam spread is awesome. High beams are like having spotlights fitted.
  • 5 weeks later...
  • 3 weeks later...
Made the mounts for the FMIC. They just touch the grill mounting tabs on the front bumper by about 3mm so I'll have to dremel a little bit off but it won't be noticeable.
Also did the hot side piping and some of the cold side but forgot to grab a 3" 45 degree bend. I plan on making it 3" to the throttle body eventually as I need to run a 3" to 2.5" 45 degree reducer currently.
  • Like 3
  • 5 weeks later...
Made up the rear subframe front brace to finish off the trio. I'll make a few more up as usual and will look into gearbox bracing next.
Also got around to fabbing up the 3" IC piping that goes to the throttle body so it's full 3" from the FMIC. Just need to finish tidying up around where I silver soldered the nipples in and the BOV flange needs facing.
  • Like 6
Finished off fitting the FMIC and wrapped the 3" throttle piping in heat reflective tape.
Next on the list is to make up a few little brackets to relocate the sensor and solenoid and clean up the hosing.
  • Like 3
  • 5 weeks later...
The plastic under body engine guard was looking pretty poor so I decided to make a new one up out some ali sheet. I made up a template and cut out a simplified version of the factory one. But what do you do when you don't have a sheet metal bender?...
You make your own one; and it works f**king mint :happy: It's a heavy duty sucker that will do up to 3mm sheet and stores away nicely with removable handles. I still need to add some vertical supports to the angle that bolts down on the sheet and drill some holes to mount it to the bench instead of using clamps.
So with that side project made, I bent up the sheet and you end up with a nice shiny undertray.
I'm also working on something else too as you can see but it's still in the "refinement" stage.:1311_thumbsup_tone2:
  • Like 3
Made up a smaller reo bar so I can fit a FMIC in without having to change condenser fan and also make more room to fit in a trans cooler.
Hey, any chance I can get the dimensions of that front bar? The length. I was considering doing the same type of thing to mine because of my fmic!
  • 4 weeks later...
On 29/12/2017 at 10:58 AM, jordanricketts3 said:
Just the length of the bar itself and how far in you did the bends
Sorry for taking so long to get back to you.
Bends are 130mm from the ends and total bar length is 690. Just make sure you slot the holes in the mounting plates otherwise it's a PITA to get on.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
