Built both heads up today. Only put Supertech valve stem seals in and OEM for the rest as there are no aftermarket springs or valves available for these.
I now have a 4 week delay on rod bearings from Japan so that's pretty much all I can do until the new year.
  • Like 2
Not much of an update but painted N1 vents and parking stick thingo.
Also cut out the middle of the bumper to suit the new plates and gain more airflow as these like to run hot.
  • Like 1
Don't like how big and bulky the airbox is and the stupid sound suppression part that just collects sand!
Started off like this
Chopped it in half and then I was left with this nice flat surface to adhere the new mounting section to.
Also noticed that the round section actually sits outside the chassis rail in the wheel arch, so incorporated a cold air intake port into the new piece.
  • Like 2
Finished re-sleeving the whole harness tonight finally. What a mission but I think the outcome will pay off with a much neater engine bay. All I need to do is buy some larger clear heat shrink so I can branch the connectors off to where they need to go.
I won't tee it all off though until its on the engine as I might be able to re route some it to further neaten it up.
Not Rywire or Chase bays spec but gives it that little extra professionalism.
Got the turbo back from getting rebuilt by MTQ as well. Shaft and cartridge journals were scored, some bent turbine fins and a small crack in the rear housing.
The rod bearings are going to be here until January now, so when I get back from Holidays it's go, go, go!
Edited by Sack87
  • Like 2
  • 3 weeks later...
I got the engine to a stage where I could bolt the gearbox back on and drop it on the subframe. I can easily roll it all out for the remaining work to do on it for ease of access.
Had more delays in timing chains not being in stock locally and having to get them from Japan again and they won't be here until next weekend. Have some small bits coming from over East too which were supposed to be here by Friday but not coming until next Thursday, otherwise I would have bolted the whole lot back in the car.
  • Like 2
Engine harness is all but done. A few little brackets to be made and two more connectors needed. It's 10x neater than what it was.
Injector harness is almost fully tucked.
Degreased the engine bay as I'm 95% ready to bolt the engine up to the body. Someone else has already been in here before me.
  • Like 1
Can you tell us what you had done to the turbo? Looks like a bigger compressor wheel... steel/inconel turbine? Cost? Expected power? So many questions... :)
Looking good by the way!
Edited by andynogo
It's a Billet Intense RS I bought from Scotty a few years ago. You'll find heaps of info on it in the turbo upgrade thread, but good for 500hp he says.
  • Like 1
Very good- should make some decent power!
On 1/28/2019 at 7:53 PM, Akshunhiro said:
Looks like someone had the joy of swapping out the turbo!
Yep. Everything has silicone on it to seal it up, including water hoses onto pipes. I bought a dud...
Got it bolted back this afternoon after doing heaps of little things around the engine that are hard to get to when it's bolted in.
Still heaps of fiddly little shit to go though
  • Like 5
  • 3 weeks later...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
