Hi guys.
So, never made a build thread for my first get, and have had some people say they wish I had.
The one decent mod I done, I placed in the appropriate thread.
Now I have a 2nd gtr, I'm wondering if there is any interest in a build thread for it?
If so, I will continue this thread.
If not, I'll leave this thread and just do what I do.
Hit like or comment.
If there's a few interested, it shall be done.
Thanks, and have a great day :)
  • Like 14
https://www.sau.com.au/forums/topic/471999-is-anyone-actually-interested/
#RIPAntz
Glad to see you are saving this thing Luke. Was sad to see...
Can i have the skirts? lol
They're not genuine.
They're 1 piece reps.
The ones on my gold one are genuine 3 piece and rear pods :)
Ok, so here's a list of what it needed(that I can remember):
Front bar and lip
Head lights
Corner indicators(and wiring)
Front and rear struts
Front brakes(calipers, pads, rotors)
Intercooler
Boost Pipe work
Heater hoses
Wheels
Passenger seat
Clutch
Ecu
Radio
Engine(incl injectors, etc, etc)
Exhaust
And love.
A list of some of the goodies I found on the car already:
Whiteline away bars, front and rear with adjustable links
Adjustable upper control arms front and rear
Very decent fuel system(twin 044s to my knowledgeb with full Teflon lines and surge tank)
Recaro drivers seat
Haltech ethanol sensor
Led tail lights
Short shifter
Eboost(2 maybe)
Momo steering wheel
Zeitronix ethanol display
Alloy radiator
And is pretty freaking neat underneath with exhaust heat shields still in place.
Thought the front bar and lip would be the hardest thing to find(due to having a budget in mind).
But, found one not to far from where I collected the car.....
So picked it up at the same time.
