Not sure what Pete does but I hadn't planned on it. You would run a cooler on the return line if you wanted, or just some extra length of line and loop it to increase the length of hose used which will help cooling a little
1 minute ago, ActionDan said:
I've thought about elec steering before.
What's your main reason for the conversion? I have seen RB PS pumps split apart at track days, is that he reason or less parasitic loss?
Na I am sure it does help there but f**k all really
main reason is the removal of stupid lines up front
renkves the pump
high pressure lines to rack that all run under and over the crossmember and then the Lo pressure line that does a loop and head forward to the cooler
so it frees up space up front removes the weight to the rear and allows you to run a inline cooler under the car which helps with cooling up front
makes mounting a high mount turbo easier with now resivour up front as well
IMG_6880.thumb.JPG.ee5806ab85ce0ed15d101e124d89ff7c.JPGIMG_6881.thumb.JPG.9d96e6c1f19249212d58cd5bcf936ce2.JPGIMG_6882.thumb.JPG.3550c4eec0086f3e4ef237e36f9e076e.JPG
The rack lines are at the rear as well so will make getting that top starter bolt heaps easier too
  • 3 weeks later...
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
    • I'm getting PTSD flashbacks seeing that name again.  With my turbo swift, I got 1,500km of street use on a Jim Berry clutch before it exploded and took out my input shaft with it.
    • It always seems the uglier an animal is the more is costs
