Time for a serious stance discussion
what kind of exhaust tip do I need
all input appreciated* to make the car hectik
the exhaust is 4 inch straight through with one muffler and a hot dog
ADCE75CC-3DAF-438E-B891-63034B2DD6EA.thumb.jpeg.6b4b4ea36d03f79d1b3ecb0f7109568b.jpeg7EF154E9-2CBE-40AD-B667-17E26459A20D.thumb.jpeg.f82a2f42877d1c2732aedbb2eaaed5fd.jpeg39A522A4-E1A6-4305-8E1F-44F5A22A5C0D.thumb.jpeg.25cec8fe5d5f1c8064221e47f319e1e1.jpeg
* please not like dan above I will listen to all opinions then do the cheapest one eg no tip most likely
  • Like 1
Given this is a track car, just make it flow well and not be too loud. Wanna be able to hear the bearing knock as soon as possible.
Dunno about bigger power GT-Rs, but on my shit box Silvia we lost power down low and didn't start seeing it come back til the upper RPM limit when testing side exit.
Use whatever shit you have to make it as cheap as possible.
Given this is a track car... it should always be in the upper rpm range....
I didn't say it made it all back and then some, I said it only just started seeing it coming back.
It made less peak, less down low and we ran out of revs.
4inch is plenty big enough. Will gain nothing from side exit besides shit sound if you're into that.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
