Both drivers are quite competent, the GTR is just harder on tyres, brakes, needs more "management" to produce a good time.
Hopefully I haven't stuffed up building this engine, going for too much power.
Can always turn it down, but that's gay.
  • Like 1
1 hour ago, fatz said:
also why the 500kw gtr are slow at the track... cause it’s very easy to drive a fast car slow
Jesus... i'm feeling very attacked right now!!! ???
But my main reason for going slowly is lack of seat time and the expense of binning my GTR. My crummy Audi on the other hand. Zero attachment, minimal cash input...
Crashes GTR: cries for months,
Crashes Audi: huh... now what? Wonder if I can drive it in two wheel mode and drag it around like a dog missing two legs.
Girls 8 and 6 I am basically at a nail salon 24hts a day
cost money to party hit up racepace ... it’s cheaper that buying the fancy shit that is just averge ( this is seconds a lap faster than you generic shit.. indeed only thing better is mca gold that I have tried and only marginally but they r 7k)
I too am victim to DIY salon work at times...
Steve why you feeling attacked We're talking about punting track cars around, don't think anybody is expecting you to punt around nice GT-Rs
As for the slow car thing, yes that's why I have an old Silvia, so I can beat on it and not GAF.
  • Like 1
I kid, i kid. I think i'm going to have to get the Audi out there to something so I can get all my frustrations of life out. :D
  • Like 1
1 minute ago, fatz said:
Audi’s r junk
so destroy it
I like this attitude. :D
But sometimes I need something to block my driveway... :)
Just now, ActionDan said:
Don't you mean Audi RS junk?
Believe me when I say, this is a million miles from being an RS. An Arse, maybe, RS? Noooooo.
How's the Q7 going anyway?
We had one in our group over the weekend and it wouldn't start. Luckily I always have my ODB2 dongle in the car, plugged it in and cleared the speed sensor fault code and away it went.
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
