Hey all
looking to stop some body roll on my track only r33gtst
im getting some HSD monocoils with 8kq front 7kg rear
ive had some shocking body roll problems. it only has a half cage at this stage, but will be adding side intrusion bars soon.
What would you recommend? still have stock sway bars etc
https://www.sau.com.au/forums/topic/472503-body-roll/
to reduce body roll u have to upgrade swaybars, thats essentially whats controlling it.
harder springs wont really fix body roll.
cage/ bar work will only really affect body flex, not roll.
Edited by GH05T
https://www.sau.com.au/forums/topic/472503-body-roll/#findComment-7856238
I agree, its interesting though that mca suggests using stock sway bars with their shocks and to control roll with spring rate. Personally i run whiteline bars but it's hard to argue with mca when you look at the performance of their time attack car.
https://www.sau.com.au/forums/topic/472503-body-roll/#findComment-7856266
well, there is kind of a religious war out there about whether springs on their own are sufficient, or whether sway bars and springs are better.  In production cars we have to run stock sway bars so we run heavier springs (ie the MCA and common Japanese approach) but when I'm not doing prod cars I run heavier bars and lighter springs and I think it handles better, particularly over bumps.
The MCA time attack car is a good advertisement, but not really relevant for the average full chassis race car.  Only time attack cars run on the smoothest track, 1 lap at a time on super soft tyres and with massive downforce. The rest of us live in a world with compromised track surfaces or roads with plenty of bumps, little to no downforce and tyres that are expected to last hours of racing and not degrade.
https://www.sau.com.au/forums/topic/472503-body-roll/#findComment-7856273
its definitely detrimental to go big sway bars for no reason and definitely bad to be too heavy, but same for spring rates.
fair to say though if you have heavier spring rates and still struggeling with body roll that the stock swaybar setup is not holding its own enough.
Edited by GH05T
https://www.sau.com.au/forums/topic/472503-body-roll/#findComment-7856276
Very good explanation, thanks Duncan. Im quite happy with my bar setup although my rear unknown spring rates are probably a touch firm on the street. Quite good at the track though. I suppose you can't have it all without a bit of trial and error.
https://www.sau.com.au/forums/topic/472503-body-roll/#findComment-7856292
Firstly - is the body roll causing problems? Or are you indicating a handling problem?  The real objective is to chase an acceptable balance front to rear for understeer/oversteer without spending big on components (eg why go to replacement bars if you can get a workable outcome without changing from OEM).
Tyre size and spec WILL influence what suspension spec is necessary or best.  eg. a set of 235 ADO8R vs 295 A050 will require different choices.
Secondly, a nose heavy boat WILL tend to flog its front tyres. That's unavoidable.
I'd review what ride height you have it set at, as this impacts roll centre and the tendency to resist body roll.
Then I'd contact MCA, speak with Josh about your needs and his prices and recommendations.  Then make a decision whether you want to run with their product or the HSD you have mentioned.
Quite probably it's going to require 13kg fronts at a minimum.  Ignore what GTR owners use, this is a 2wd chassis with different requirements.
https://www.sau.com.au/forums/topic/472503-body-roll/#findComment-7856346
Be cautious mating the 24mm bars front and rear.  I have them on a 32GTSt (so I acknowledge not the same chassis set up, but nevertheless.....) set to max stiff front and min stiff rear.  I really feel that the mid corner balance would be better if I had a 22mm rear.  It's very happy to make the rear step out, which becomes progressively more alarming the faster you go.
Otherwise.....yes, just do it.  Or at least do something.  Stiffer front bar drastically sharpens the immediacy of turn in response.
https://www.sau.com.au/forums/topic/472503-body-roll/#findComment-7857130
Wow. OK. Understeeeeeeeeeeer.
Looked up the Cusco ones as a comparison (%'s compared to stock).
Front
Cusco 24 dia, 192% stiffer.  ARC 30 dia (From your number) 240% stiffer.
Rear
Cusco 30 dia , 162% stiffer. ARC 30 dia 180% stiffer.
Guessing ARC quote the numbers with the drop links on their hardest setting.
https://www.sau.com.au/forums/topic/472503-body-roll/#findComment-7857181
Front
Rear
They are quoting 2.40 times stiffer at front and 1.8 times stiffer at rear
https://www.sau.com.au/forums/topic/472503-body-roll/#findComment-7857199
I went for 12kg/10kg rates on BC Racing ER coilovers, still using stock sway bars.
Yes, it still rolls a little, but you also need to consider the relationship between sway bars and springs.  A thicker sway bar will help reduce roll, but you'll also lose some suspension independence and comfort (lol what's that anyway?) on the street.
I can still manage a 1:35 around Winton with a bit more in it, so I'd try going for a good shock and spring setup first before adding sway bars.
Pic is of my car (like yours - half caged) at pretty much full load.
https://www.sau.com.au/forums/topic/472503-body-roll/#findComment-7857296
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
