Hi All.
I have tried searching and found huge amount of information, however looking for advice to narrow down my selection.
Starting out with a completely stock GTR R33, would like a well rounded package targeting 450hp at the wheels on pump 98 fuel. Appreciate any advice on bolt on twin turbo upgrade selection and any other supporting mods needed. Car is a street car, do not want to move to far away from the standard drive ability.
thanks in advance
https://www.sau.com.au/forums/topic/472851-r33-gtr-upgrade-advice-needed/
In before everyone says do single turbo.
Because seriously, do single turbo if you want to get that sort of power and maintain street driveability.
If you really, truly must maintain twins:
-9s
HPI dumps
plazmaman cooler
good injectors
good aftermarket ECU
headstuds/gaskets
This might just make your desired power on 98, might also not but they're smaller turbos so shouldn't hurt your driveability much. Would suggest you go for a ride in a car with -5's on 98 and determine if that meets your driveability criteria before considering that size turbo
20 minutes ago, MrSquigle said:
Thanks for the reply's
not wanting to change the car to much, happy to leave it twin and standard looking. Are the Garrett GT2860r a decent upgrade from standard?
Flick through this. Your question has been answered 11ty times.
1 hour ago, r32-25t said:
it’s beleived then -9 will make fractionally more power but they both respond the same
Speaking from actual experience. Changing from R34 N1's (-7) to GTSS (-9) there was a re-markedly big improvement in response.
The -9's were on sooner, harder and stayed on the boil for alot longer
  • Like 1
Were the -7s stuffed? Cause I’ve driven both and couldn’t tell the difference
-7’s were perfectly fine. I was pleasantly surprised when I got the car back.
There are plenty of dyno read outs in the 26 thread and a lot of the 7’s get 20 psi closer to 4400rpm which is about what I was getting.
9’s were on 20 psi a good 500 rpm sooner .
-7s nosed over to 19psi by 7500 rpm.
9’s stay 21-22 psi all the way to 8000rpm
Same motor, exhaust, ecu etc
If you want to do it on the cheap with minimal mods you can buy all second hand bits for a basic -9 upgrade but you will need to run reasonable boost to get to 450rwhp on 98. Other options are mild cams, say basic 260 tomei, but everyone complains about the drive ability afterwards as they have soft ramp rates or E85, which will get you there with less boost and lower EGTs. Fuel economy will suffer though, but you can always run a flex setup if it's a daily and run 98 for commuting and E85 for an extra 20kw for track days or whatever.
You could also do a basic single conversion, not a kebab spec full twin scroll EFR setup, but just a basic new gen Garrett on a reasonable manifold, single gate.
If you want to stick with twins, I'd recommend -9s. -5s are too laggy for the street without a few accompanying mods, -7s run out of puff too early. My 2 cents :)
If I had a GT-R and didn't want to spend stupid amounts of money to make it fast, I would do all the handling, suspension, braking, cooling mods first.
Then go thrash the living daylights out of it on the track.
Once I am ready, would drop in ARP headstuds, higher lift cams, and a big sexy single.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
