57 minutes ago, Sovereign337 said:
If you haven't previously held a license, what do you guys recommend? AASA or L2S?
Shane!!!! L2S will be a little dearer, but it'll cover you for more events. On top of that, CAMS licences are accpeted by AASA, but its not necessarily the same for AASA licences at CAMS event.... @crashdown will need to confirm....
  • Like 1
Ladies and Gentlemen,
As part of each member's entry to SAU NSW's GP Track Day, Heasman Steering will be hosting a tech night on corner-weighing, shock rate design, and suspension set up for the track.
There are limited spots available, with 10 dedicated spots for members, in particular those who've entered GP. We'll be posting up a separate thread on the tech night to open it up to all members, but for now, for those who've entered GP, please let us know if you're keen on the tech night also.
Final details will be shared in the members thread in the coming days, but it will be held on one of the thursdays leading up to the track day.
First in, first served!
  • Like 1
I would be interested in attending
So to be clear, does that mean that the 1 day CAMS license is no longer available?
Got a couple of mates who are keen for the trackday but not so keen at having to buy the yearly license from CAMS.
I'll need to find that out for you, from the club executive in charge of that department. I will follow that up and get back to you with a reply.
We can supply a day licence.
Could you please let us know how many you would require (even if it is a max amount) before this Friday 20/4.
This is because we need to ensure we have enough available.
Thanks for following up.
Max would be 5.
I've got 3 definite and 2 tentatives
Max would be 5.
I will have 5 put to the side.
When they pay for their entry, let me know and I'll then allocate a day licence to each name. That way the sign on desk, will know on the day.
Greetings guys, not sure what the go is as its been a millenium since I've set foot near a track in a car.
Can someone please give me No.26 and link this forum name to my member number as I thought it would have been deleted soI left it off lol.
Much thanks Easto
  • Like 1
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
