Hey guys, I’m fairly new to the skyline scene, but looking to buy an r34.
My plan is to eventually upgrade to a larger turbo, maybe make 400-500 hp.
Is it worth paying the extra $5000? for a gtt if I am going to redo the turbo system anyway.
I understand that there are other upgrades in the gtt, but I am not sure exactly what.
I am not sure how much more expensive it is to turbo the gt model, compared to upgrading the turbo system in the gtt
Cheers,
Josh
https://www.sau.com.au/forums/topic/473512-r34-25gt-or-25gt-t/
Please do a search for RB25DE+T or DE+T e.g. https://www.sau.com.au/forums/topic/335781-r34-rb25de-to-turbo-conversion/
In short, turboing an NA car is not worth it. Here's what the GTT has over the GT, among other things: stronger gearbox, bigger brakes, bigger wheels for the bigger brakes, rear swaybar, sidemount intercooler, everything in the right location in the engine bay. Possibly some differences in cooling also (rad, PS, auto gearbox). Fully converting a GT to a GTT is possible but a big job - just save up and buy a proper GTT. Better yet, buy someone else's 500hp car with everything done already.
Another solid myth is that buying an auto can be magically converted manual cheaper that buying a manual in the first place. Not true. Been there done that. If you want a manual, buy a manual.
Good luck.
  • Like 2
Good luck.
Agree with your points although buying someone elses 500hp car is not always the best option. I'd rather a stock/fairly stock and do all the work myself, that's half the fun of having a project car isn't it? Building it to where you want it to be as well as the fact you know the car has probably been thrashed already if it has 500hp.
Edited by Gymkhana
  • Like 1
Good luck.
Cheers for the help man, kinda figured this would be the case; but didn't know there were that many differences.
  • Like 1
Yea for sure, definitely going to buy a fairly stock car, looking to keep this as a project car for the next couple of years at least
Only trouble with that is you lose your social life, own 2 pair of jeans [one with holes in the knees] and around 4 or 5 cheap T shirts with grease spots and welding/grinding holes in them and you live on noodles or cuppa soups cos you have nil time and $$$ to waste on food or clothes when there are important things like manifolds and turbo's to buy.
BTW....I have a THAT wardrobe, but my diet has progressed a little bit :) to include meat etc
Oh and get used to your gf/wife/partner rolling their eyes
But its all a journey...good luck man.
People forget that buying a finished project car isn't missing out of the fun of a project car.
The "fun" of a project car is keeping it running and trying to use it. There's more work in keeping it running than there EVER is in building it.
Buy Jussi's car and be happy
/Thread
  • Like 2
I don't think anyone's pointed out yet that the power you can get from a genuine DET will always be more and easier than from a DE+t. So if you have a particular power figure in mind you might only have one choice really.
I've done the DE+t and the sense of satisfaction is pretty awesome. I'd have had to wait a lot longer to buy a GTT and the moment might have just slipped away. Keep saving and watch the prices rise. My budget would probably have got me a GTST at the time but I wanted the R34. It might have been non-turbo for a few years but at least I was driving it. I gradually did the supporting mods - brakes, suspension etc.  before the turbo conversion. If you're ok with spanners it's not hard, not particularly time consuming and not that expensive if you're patient about looking for good deals.
Perhaps in the UK but certainly not in Aus or NZ :)
The cheapest GTT right now on CarSales is AU$8k. TradeMe has one with a 26 in it for NZ$10k...
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
