Hey i’m looking to buy a skyline this week and i need your opinions on whether or not it will be a decent buy
it has a broken speedo
heavy steering (problem with the power steering may just need fluid)
and a a squealing sound on the start up of the car
all in all i got the guy down to $2000
https://www.sau.com.au/forums/topic/473745-buying-an-r33-skyline-rb20/
6 hours ago, Jordy32 said:
Have you driven it? You'll literally get beaten by stock i30's it is going to be slow.
New belts, possibly new PS pump, new speedo. Budget a couple hundred to get it back in shape..
Lot cheaper than an i30 though. i30s are cool.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
