Hey guys,
I d like to ask for advice... My newly bought skyline running perfectly on 7 psi but if i raise the boost to 10 psi it cuts out at 6000 rpm and i just cannot tune it out.... when the engine is hot its getting worse (5500rpm)... I connected a  smoke machine to check for leaks...I marked the blocked pipes with red X....the smoke is immediately (at low pressure) coming out from the crankcase and from the inlet manifold...
It just doesn`t make sense to me how can it smokes from the engine when everything is blocked... Is my turbo leaking through the bearing housing back to exhaust and through the open valves comes out at the inlet? Or is it normal? Any idea? I m kind of getting hopeless for now maybe just i m the dumb and cannot tune it out (datalogit power fc, Z32 maf)... pls don`t spare me everything helps, have a good one
https://www.sau.com.au/forums/topic/473789-rb25det-turbo-leak/
Sorry about that i just didnt make a picture how the smoke was connected so i tried to improvise.... I connected the smoke to the inlet before the turbo (blue arrows).... I blocked the inlet from the intercooler so it should hold the pressure... but it s not holding any pressure since the smoke is coming out from the inlet manifold and the crankcase where the red arrows are with the ???.... And that s what i m asking if it s normal?
I assume you have the breather pipe and bov plumb back pipe blocked that comes out of your stock intake pipe. Try blocking it closer to the turbo, for example, block it before it enters the intercooler.
or, enter smoke right after the turbo and block off the same as your picture^^
NEO25T: I think I m gonna try it on the weekend
Kinkstaah: yeah it is an Apexi Power FC with Datalogit I have a log file what is happening...
the AFR at the cut point is about 10.75 (so it s not too rich or too lean) I ve tried to adjust the airflow data....change the whole MAF...still the same... after the car is hot the cut is happening at 4320 mV or less... It is a Garrett GT28 turbo, 7psi wastegate with a turbosmart tee set to 10psi
RB25detonator: yeah i ve done it too leaking out on the same places (crankcase and inlet)
Out of curiosity how did you block the pipes?
The easiest way i found was to bag the end of the pipe with black plastic and clamp it back together.
What spark plugs are in it, thinking back mine cut out like a rev limit at 6k when i got it. The plugs in it were nasty and new ones fixed it up
On 4/18/2018 at 8:50 PM, Ibanex said:
yeah I used rubber gloves with clamp for alloy inlet and for the hose used degreaser can and clamped it  for smaller pipes just bolt and clamp.
I thought about the plugs too and I changed them last week for NGK BCPR7ES... they should be fine right?
They should be OK but Iridiums better. If you still have stock coils are your plugs gapped down to ).8mm?
the only thing is that it really doesnt feel like a missfire...it just cuts out all together...  these plugs came already gapped to 0.8mm and the coilpacks (blue splitfires) should not be older than 2 years... so not too much left just keep on experimenting and spending some money...
If that is a full WOT pull, from the entirety of the video (i.e not backing off) and boost is dropping into massive vaccum like that, I'd be putting my money on that stock silicon hose sucking shut.
Especially given you said it runs fine on stock boost...
  • Like 1
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
