As the weather is warming up I've noticed that my 32gtst is not starting from cold as easily as it does or should compared to winter time, we just had a really cool morning and the car started first crank, when the engine is at operating temp restarting is fine, always first crank, it just has an issues starting first start of the day when ambient temps are over 25c
Any suggestions before I start playing around in nistune?
https://www.sau.com.au/forums/topic/475135-tune-question/
On 10/12/2018 at 9:21 PM, burn4005 said:
Probably need more crank prime at warmer areas
After looking at the tables I think you are correct, I've added a couple of percentage in the 20c and 30c blocks of the cold crank enrichment table., have to wait until the ambient tenps warm up to see if it made any difference.
https://www.sau.com.au/forums/topic/475135-tune-question/#findComment-7887810
  • 1 month later...
Update: my correction to cold crank enrichment has worked... starts like and idles like a champ once again.
So now I suppose I should start looking for any air leaks, but only when all the rubber is cold.
  • Like 1
https://www.sau.com.au/forums/topic/475135-tune-question/#findComment-7893068
    • Well, in the same way that you can't tell any SUV from any manufacturer in any size category from any other one, "sports" coupes now all look identical. Stand back and squint your eyes and the Supra and the 400Z and the GR/BRZ things all look the same. I was just thinking last night, when sitting behind a Subaru CrossTrek, that I have no idea what it is, how it differs from an XV, or a Forester, or an Outback, or anything else Subaru offer, and I couldn't tell if it was supposed to be small, medium or large. I contrasted that to the good old days, where a HQ Kingswood had familial similarities to an LJ Torana, but there is no way that you could confuse them, and how a bit later, the HX Kinger and the concurrent Torana and the Gemini all had familial similarities, but you still could not confuse them. Ditto the ugly Fords and Chryslers of the era. But now, a RAV4 looks like a Kluger, looks like a Yaris/Cross/whatever they're calling those stupid f**king things, looks like every other Toyota that's not a Camry/Corolla sedan.
    • The Prelude doesn't look that bad without all that lens distortion in those pics. Makes it look disproportionate when it isn't. Actually I kind of liked it at the Osaka Auto Messe earlier this year.
    • Pour in the highest octane, non-ethanol fuel you can get and see if the readout changes. If it's dead bang on 11% then I would question the sensor. Another quick test, just take it out and run normal (in an american accent) gas-o-line through it and see if the sampled ethanol or lack of changes.   United E85 here in the land of drop bears does vary a bit, I've had as high as E87 (could be water in their tanks too, who knows)
    • Yep. And if you ever do, you'll just have to deal with it then.
    • E10 is pretty tightly regulated in percentage. Too much and engines can't adapt. Every incentive is against them to have too little ethanol though. The more ethanol the higher the octane.
