Hello,
I've done alot of searching and havent been able to find anything specifically
I just bought a 96 R33 GTST has current rego in nsw and pink slip, it'll be transfered to Vic.
It has almost 190,000 kms on it even though it has a good service history i know there comes a point where all cars need to have a major service on them, my question is what do i need to do? Never done anything more then oils, coolent and sparks
If someone could let me know what else should be replaced that would be great
https://www.sau.com.au/forums/topic/475304-major-service-needed/
You say it has a good service history - look at the history...what has been done at 100,000? If there is in fact no info, no sticker to say the cambelt has been replaced then search for a major service list (no its not the same service every time - infrequent items include the cambelt, water pump, changing the brake fluid). You will be able to find a comprehensive service list by searching.
If I pick up up a car with no, or questionable service history I do everything up and including the service required at the current odo reading or date.
For a car with 190k on it I would, without looking at the owners manual because I don't have one...
Flush every oil and fluid and replace every oil and coolant, engine, gearbox, diff, coolant, brakes
Every filter
Timing belt
Water pump
Idler
Spark plugs
I would inspect and change if required:
All heater hoses
Rubber brake lines
Brake pads/discs
Wheel bearings
Serpentine belts
Dampers
Bushings.
There is most likely alot of stuff I've missed.
Find a owners manual or post with required services at intervals
Once I have serviced the car to the best of my ability I will take it to a "good" workshop and get them to run it up on a dyno for a health check, and inspection, a good mechanic can diagnose and maybe pick some things missed by me.
As for parts, only change the things that require changing, it's gonna cost you a heap, don't waste cash on things that may not be required.
Once it's serviced the next vital step, which is most important, is to do a skid....
http://www.skyline-owners-club.com/forums/downloads/R33_All_Engine_Manual.pdf
The owner wasnt able to show me any recipts apart from a HD clutch being installed last year but they reassured me it was done.....so im going to replace the all belts, fuel filter, do the oils and coolant, tranny oil, brakes, maybe rotors if it needs doing, brake fluid as a maybe, maybe the knock sensor and thats all i can think of unless ive left something out then go get it dyno'd and maybe tunned, does anyone in the wodonga area know of any decent dyno places to go to that wont cost an arm and a leg?
Edited by FedBpy2018
  • 3 weeks later...
water pump, idler wheels, wheel bearings, diff oil, injector clean, there is a workshop manual online somewhere.  Find it and download it.
Here is one location: https://manuals.co/workshop/nissan/skyline
Unless it has an aftermarket ECU [nistune, Link, Power Fc etc] getting it dyno'ed is probably a waste of time tbh.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
