Hello,
I am looking for 550-600hp in my  RB25. The engine is 4WD from Stagea
I run GTX3071r and custom made intake and exhaust manifold already.
I am planing to get forged pistons and rods soon and i have a question about the head gasket and camshafts
What thikness of the head gasket should i use?
Do I have to change OEM camshafts for this power or not? Can i run OEM head with this setup?
Car is dailydriven not for track use
thanks
https://www.sau.com.au/forums/topic/475632-rb25-550-600hp-mods/
13 hours ago, GTSBoy said:
Need to specify "at the engine" or "at the wheels", otherwise these misunderstandings will happen.
Fuel is a biggy here, too.    whp running 91RON on a heartbreaker Dyno Dynamics will be hard hard work, estimated flywheel power on a Dynapack using E85 will be easy as pie.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
