Hey Guys,
Had to replace my Boot/Trunk Lid for my series 1 R33 as the other was broken into. Got one from a guy on gumtree pretty cheap but oh man for whatever reason its not aligning and the gaps are huge, can fit my fingers in them. Anyone have any ideas or what the go is? spent hours on it and got nowhere. The main issue is where the taillights and the skyline garnish is.
Not sure if it is because of the aftermarket tail lights.
See attached photos.
Any help would be great guys.
 gaps.thumb.jpg.2274978a4f44deb4d424a5c4308b5321.jpggaps1.thumb.jpg.4bc89fd04a1f5a010a0a08bdbf7fd0d4.jpggaps2.thumb.jpg.de8a2c6410998cf4682d72dc5a3c9e9d.jpg
https://www.sau.com.au/forums/topic/476588-r33-boottrunk-lid-alignment/
Pretty sure that's normal, it's the side camera angle and the white paint making it look weird I think.
My R33 has the same sort of gap aswell if I look at it from a similer angle. Mines purple with a black boot so not as noticable.
Edited by ossy
It's always bugged me aswell but I'm sure it's normal. My purple R33 has it and so does my brothers. I've also seen several others at car meets as well.
I tried to get a close up of the same angle if it helps.
Edited by ossy
This is getting so annoying. The gaps for my boot are huge and not like others, it's like my boot latch is not catching but it is cause I need to unlock my boot to open it when shut.
I can literally put my whole hand through the gaps and pop open the boot.
If I remove the latch the catches the boot lock the boot sits really well but ofcourse this is not going to work cause I need to lock my boot.
Anyone have any opinions on what's going on here.
Check out these photos. Huge gaps.
Edited by blitzer31
Added more info
Hey adms15,
Yeah I did try that, there isn't much of a difference. Ill try again in daylight and let you know what I come up with.
If anyone knows of any links or help online please let me know, I have googled so much.
Dan
  • 1 month later...
Hey guys,
Think I have an idea what the issue is. Removed the bumper and played around with the latches on the boot lid and body but still same. So then I started to look at the after market tail lights and found that possibly these lights may not be 100% correct fitment. Loosened the nuts and pulled the lights out a bit and now its looks normal. What do you guys think? Maybe I can source the original lights and see what happens.
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
