  • 1 month later...
16 hours ago, ActionDan said:
Looks amazing. Keep a good layer of your preferred sealant on it, boy do reds love to fade lol
definitely going to protect is as much as I can lol.  Gettin the main dash painted to match and then bolting up all the carbon fiber pieces.
51 minutes ago, ActionDan said:
You're painting the dash? Which parts?
basically the whole main dash itself.  i have a carbon fiber glove box, carbon fiber radio bezel down through the entire center console, the steering surround, and the gauge cluster surround.  I also have a sheet metal rear seat delete and sheet metal door cards that I am going to have hydro dipped carbon fiber to match as close as I can.
2 minutes ago, ActionDan said:
so what colour are you poainting the dash itself?
red to match the car.  I just got a truck from someone that has a paint matched dash and I love it so I am going to do the same to the skyline.  only way to really "modernize" the dash so the interior doesnt look so dated.
Well, it's not my style, but it's your car and you've got to love it.
If re-sale matters to you, I would strongly suggest not doing that particular mod, but if that's not a concern, go wild and enjoy it :D
  • Like 1
I will be buried in this thing at this point.  There is way too much money wrapped up in it to ever bother selling it.  When I say ground up, I mean ground up.  There's not many parts or pieces that havent been upgraded or replaced with new oem parts.  It will basically be a brand new car that I plan on driving every damn day! haha
  • Like 1
1 minute ago, K_arlstrom said:
Bold move! Need to see how it ends up
follow the build.  now that it will be back at my house tomorrow, I get to really start digging into it and putting it all back together!
15 minutes ago, K_arlstrom said:
Will do! I'm two steps behind you but probably close to 45k AUD deep into my rebuild... Always a comfort to see someone else go all out too ?
Im almost 75k USD into mine so far but Im about all in. Not much left to buy at this point.  Its all piled up in my basement ready to go.
Best type of insanity! My worst fear at the moment is that my car will get too good, that the driving will feel dull since I can't use its potential.
Oh well, back to topic, this is your thread after all! You went with a trigger kit, s13 subframe and newer color. Got any other modification to share with the rest of us? Found the thing that will make it truly your car? (maybe the dash?)
Better than drugs right?!  I also went drive by wire with a 350z pedal and a ctsv throttle body.  Going full air suspension and all gktech adjustable arms.  Shaved door handles and trunk lock.  Trying to go neo power steering pump to get rid of the dual stage pump, hopefully I can get that to work.  Engine was rebuilt.  New gaskets, rings, and seals.  Poncams and adjustable pulleys.  Cant think of anything else thats too crazy lol.
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
