2 hours ago, niZmO_Man said:
Yeah, how shit were the halogen bulbs?
Headlights themselves makes a big difference. E.g. dad's Camry (last of the Australian made ones) has shit projectors in them. Upgraded H11 to H9, marginal. Threw in a "good" LED bulb, looks great/bright up close, is meh while driving (so if you're after just colour upgrade and output is same as standard, I can suggest a H11 for your projectors). Can't believe we didn't get the good Koito H11 projectors here.
Oh and that "group buy", the guy wanted me to transfer money to him directly instead of going through alibaba, no deal.
But yes looking forward to the output photos, I would love to be proven wrong but I haven't seen one single LED bulb that's an actual upgrade here in Australia.
I have the Narva high intensity high beams in the cruiser, the cheap ass low beam LEDs from eBay I had in it threw light as far down the road as my high beams, the only thing the high beams did was light the tops of trees up. And I'm talking the top of the tree, not halfway up the gum, just the top. The LEDs also lit the middle of the tree up.
Only way to get more light was to flick the light bar on. Unfortunately it's more of a flood than a spot bar. Still got more distance and width, but not like I would if I ran the bar I put on the old boys Hilux.
The current Phillips low beam halogens I have are rubbish.
8 hours ago, niZmO_Man said:
What bulb socket/fitting? Also which car/housing?
FYI Narva are rebranded Osram @ double the price
In the 105 Cruiser, HB3  and HB4. Can't remember which is which ha ha
Probably HB3, as most Japanese cars are. There's a nice upgrade for those high beam, 9011. I got a bunch of Toyota HIR1 (9011) that doesn't need any modifying, goes straight in with HB3 plug. It appears on our Tarago (JDM ones use HB3).
HB3 = 1860 lm
HIR1 = 2350 lm
It's the reason why the old Osram Rallye H7 was good, it had a H9 (2100 lm) burner (H7 is 1500 lm).
HB3 = 1860 lm
HIR1 = 2350 lm
Yeah it runs a HB3, and a HB4, I just don't remember which one is high/low beam.
I'm assuming from the above HB3 is likely my high beam?
Yeah I'd assume so. But still, 90's headlights man, not working with much. LED can help IF the emitters are positioned in a way to focus off the reflectors, which basically means custom made bulb for your headlight (unless it's a fluke, impossible to happen).
Reason why Diode Dynamics in USA made LED bulbs for F150. They happen to work quite well in other headlights.
  • 1 month later...
  • 3 months later...
  • 2 years later...
On 7/7/2022 at 7:59 PM, Wirelessstiv said:
One of the important criteria for selecting LED lamps for a car is the specific base of the car. In this case, the base is designated similarly to standard halogen lamps.
This time I'm quoting the post I reported, so I can say "f**koff" to it.
Ban. Ban Ban. Bananannannanana ban ban.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
