Also came here for LED H1 globes, found nothing LOL.
Been driving around in the Tiguan (has auto levelling LED headlights) and drove the R33 the other day in the evening.
It feels like the headlights produce like 30% of what the Tiguan produces! Not to mention the lenses are clear (been polished) and it already has some Philips H1 globes in there.
Must be getting old, but it feels like I can barely see anything with the R33's lights at night.
These look exxy af, but will they perform? I kind of don't want to take the risk (feeling poor atm).
https://www.stedi.com.au/copper-head-h1-led-head-light-conversion-kit.html
You could retrofit some rectangular Mini D2S if you have the appropriate brackets, end result looks something like this, just ignore the weird carbon fiber stuff they added to the housing:
Some solid work there, as you may or may have not picked up from my build thread I have next to no time to DIY stuff these days.
Easier to find H1 globes that perform, slot them in and enjoy.
They do look ok actually, too bad we don't have those kinds of services in Australia retrofitting HIDs, LEDs from OEM applications to old 90s shit boxes.
The price is nuts if you want them to do it end to end: https://www.organizedgaragestatus.com/product-page/4nr33prcfqprde
yeah nah, not paying that much money lol.
it's all down to optics, and 99.9% of them are trash. that stedi one will be garbage, full of glare. Some reflector housings respond well to a good bulb, key word is some. Projectors = forget about it.
no point trying to raise fuel pressure when you have 100cc injectors and you want 300kW, so to speak. Or upgrading GT-R twins to some old Japanese ones :D
You can check out http://automotiveledresearch.com/ (or follow his Facebook page) for more info. Basically you want an LED bulb that best replicates halogen, which means super thin PCB and good quality emitters. You want a tightly controlled beam, as you want a good spread and minimal foreground illumination.
If you're still keen, check out https://www.bulbfacts.com/led-kits/recommended/ for some decent reviews.
There is one guy in SA that does retrofits. Hell I have a pair of R33 headlights that I wanted to retrofit OEM LED projectors into, haven't had time yet/forgot about it.
Best bet is to make sure the outer lenses are optically clear, any hazing dramatically reduces output. If the reflectors are not in good condition, no point dicking around with bulbs, replace or retrofit HID projectors.
  • Like 1
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
