Hey everyone,
Need a new clutch for more power / current one is worn, I have the GTT (RB25DET Neo) was wondering if anyone has any tips on what to look for?
Will any aftermarket single plate do? Currently looking at https://www.gameonmotorsports.com.au/npc-nissan-skyline-r33-gtr-pull-type-clutch-r34-gt~44571
Looking to make about 375kw~
Edited by thenixtone
https://www.sau.com.au/forums/topic/477812-suggestions-on-a-new-clutch/
10 minutes ago, thenixtone said:
Ah right, my bad, I thought this was a forum.. for discussions. A clutch place isn't going to tell me if their clutch is shit, are they?
Maybe they would if you asked about an unsuitable model in a particular application.
call npc. Tell them what you want. Call Jim Berry. Call acs
On that basis, we could trot out the passive aggressive claim that no-one has ever asked that question on this forum before and that it would be impossible to search for previous/recent discussion.
You mean like the original passive aggressive comment I was responding to?
And of course I searched. Its hard to find information with exact power figures. How do you think I came across the NPC clutch that people on here recommend..?
Every thread that COULD be answered elsewhere is useless apparently.
Besides 'this one fits' I was after actual experiences and feedback.
Budget? Where/how you are using the car?
I have ACT 6 Puck with Extreme pressure plate (rated to 830nm iirc) on my rb30/25 street car (550hp/730nm) and Im happy with it. We dont really have bad traffic here where I live though
On ‎18‎/‎07‎/‎2019 at 4:46 PM, WR33KD said:
OS R3C here aswell, only clutch you will ever need
In a rwd application under 400kw yes, so fine for the GTT in this application, but not in a GTR launching at 7000rpm +. I killed a brand new one in one drag weekend, completely warping the metallic floating discs to the point the clutch wouldn't disengage.
Probably not relevant in this situation, but just pointing out that they are not the "be all to end all" of clutches at all. They also drive like shit on the street, very hair trigger engagement.
  • Like 1
2 minutes ago, WR33KD said:
Mines mint she feels like a standard clutch, done plenty of hard take offs and still feels great. I’m over 400kw and rwd and it’s the bees knees and it has a changeable centre not like others
What you got?
Jesus..
Is the difference between button and cushion button that big of a deal for street driving?
29 minutes ago, thenixtone said:
What you got?
Jesus..
Nope. The cushion has very little effect. A button clutch is going to be pretty much off or on and  don't like slipping
All multiplate clutches have a changeable centre hub by design, so thats not anything special. Maybe your R3C seems a bit nicer to drive in a rwd car, because any metallic triple plate I've had in a GTR has a hair trigger and not really slippable, definitely nowhere near a standard or full face clutch plate type. I've had ORC (Ogura), Xtreme (ACS), Exedy and OS Giken all in triples and all basically felt like the same clutch.
OP, The Nismo twin, NPC twin or even the OS giken TS2B will probably be a nicer clutch to drive for you and handle your power for quite sometime. $1500 or less though is going to limit you to buying a single plate though, as I think you'll need to stretch a bit more to at least go a twin or triple if you can afford it.
Awesome, thanks for the info. Think I'm going to spend the money and get the coppermix.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
