All,
you may have seen my other post where I mentioned of large smoke. After diagnostic, it worked out one of the cylinder had 75% leak .
Decision is now to do a full forge rebuild to support 700+ bhp at fly.
what he found out was the cylinder with issue had its injector flowing fair bit less fuel and he thinks that is what has done the damage by running it very lean.
I will list the specs and mechanic wants 3k for rebuild as labour which is almost 5.5 k in Au dollar. he is one of the best here and all he touches is r34 and skyline
there is then 2.5k which is another 4.5 k Au for parts .
I then have to spent another 5k pound which is 8-9 k Au on turbo , manifold, intercooler etc to get 720 so in total around 11k pound so almost 20k Au . would you pay that ?
spoke to few tuners and some weren't confident on providing warranty on the build due to power but he is .
https://www.sau.com.au/forums/topic/478435-r34-engine-rebuild/
No I would not. How rich are you? With 700+hp you will need a lot more spending - new clutch, gearbox, brakes suspension tyres.
Pull the engine apart and see what it needs. You may just need a set of pistons and bearings. Neo has GTR rods and oil pump so if its in good nick will support 300 to 350RWKW without forged parts.
In NZ I would be considering an RB30 bottom end for the Neo head but may not be so easy for you.
I am sure you could buy quite a nice car for 20,000 pounds but if you want to spend it on your old Skyline and that makes you happy go right ahead - but take the time to pull the engine apart and see exactly what your options are.
I agree but then with 11k uk pound, I can’t get any car with 700+ bhp
clutch is rated at 850hp, suspension all good, brake is evo
only thing that i am worried about is diff and gearbox. What gearbox do you need for 700 hp?
part cost is majority of the expense to be fair.
what do you consider fair in au to rebuild an engine?
well any tuner or mechanic will charge me above 1.5k which is roughly 2.5k au to strip and change a piston so if i am paying that i might as well do headworks and forge it !
everything on the car is there to support 600-700 bhp apart from swirl spot for fuel and possibly using walbro 450 vs 044 bosch and swirl pot.
what i need is serious feedback from some one to say if the gearbox hold up to 700-800 bhp? I won't be spending 5k on sequential gearbox  Samsonas
26 minutes ago, Ben C34 said:
The gearbox will break at some point.
Your choice is to then keep putting in stock boxes or spending the cash to get something that won't break.
that is why I am asking what people do put in that lasts .
Are we talking 200 miles or more 4000-5000 miles?
My third gear is dodgy and think gearbox will pop at somepoint .
re spending money , look to all critics here, I am not rich nor almost 20k Au is cheap.
However I never intend to sell it as it is my dream car so I might as well boost it up to 700+ bhp and enjoy it. It should be driveble with good tyres and little skill.
I have managed all the way to 600 bhp with full traction off and this is a new challange as never had a 700+ bhp car
700 bhp = 550 - 600 rwhp dependant on driveline..........on e85 it might last a while as stock on pulp not long
gearbox big jump from something that stock to something that will handle the power like PPG dogbox  $11,500 AUD new
might get start up warranty but thats bout it ...wouldnt expect anymore on a build
1 hour ago, WR33KD said:
Has any one done what he is wanting to do?
Yes plenty. It is certainly do-able - refer the turbo upgrade threads.
But it is expensive and can end in tears (engine failure).
The question is how much do you want /need it?  And that's entirely up to the OP.
41 minutes ago, drifter17a said:
Is that engine failure with full forge?
Yes it can happen. Engine life depends on quality of build, quality of tune and how it is used or abused. Then there is always an element of luck. Have a read of the "report that engine failure " thread.
This is not to suggest that it is likely but from my limited experience of track days RBs seem to be the most common cars being pushed on to trailers with dead engines. (To be honest that's two cars - one GTR and one Cefiro).
Not trying to scare you - there is a lot you can do to prevent failure  but be at least mentally prepared for the worst.
A 700hp car is only making like 40hp when driving around in traffic. As a result it can last years.
If you want to be serious about how long a 700hp engine lasts while making 700hp the reality is this is a matter of hours.
Same story with the gearbox. Think about it, do you think Ferrari and Lambo and GM are making 5+ Liter V8/V10/V12 for no real reason, why not make a 2.5 with a massive turbo on it that'll last forever if 700hp is going to last a long time under heavy use.
  • Like 1
"Full forge" engines are nothing to write home about. You get more strength to take more power yes, but it's not a magic bullet. Any detonation event when you push that hard (250+ hp/L) is going to be catastrophic. Keep in mind that forged engines need higher clearances as well, that means it's more likely that you'll get piston slap on cold start and increased wear. A stock RB25 can go hundreds of thousands of km before needing a rebuild if it isn't abused.
If you don't really know what you're doing and you want a warranty, stay conservative.
  • Like 1
yes I have
Ive done 500 - 550 hp on stock engines for 8 years (on the track) with standard gearboxs and also now 635h (so 700+bhp as op wants) , also have gone from std box to ppg dog box
you got more chance of it lasting as a road driven car than track for sure but strain is strain
Also there is no mention of fuel used - anything using normal PULP fuel going anywhere near those numbers forged or not is asking for trouble
what the OP wants is what he wants... but Id say what most of us would do would be a responsive as possible 500rwhp stocker on e85 with std box and be nice to it most of the time with occasional thrashing
  • Like 1
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
