Though I would start another thread
introducing the winefuelled r32
7 weeks till the 24 hr lemons at the bend
The concept for this car came together when we did a Redneck rally after a solid 7 night dei king heavily
basic specs
r32gtst( roof chopped off)
engine swap to a dirty rb30e
extensive bracing for the cage
important lemons information
jim Richards loves it “ we love you jimmy”
runs a 15.4 @84 mph at the strip
and is a f load of fun to drive
anyway this thread is to let to let you know how awesome we car
and if your in south Australia and near the bend come out for a beer and or sausage  on 12-15 October
  • Like 4
14 hours ago, fatz said:
Rb30e is almost as disappointing as a rb20det
Oi! Both are fun, in their own right (one revs like a diesel, one loves to rev).
I hope you get Jimbo's scribble coated or something, for that extra Instagram points
  • 1 month later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
