OK GUYS.....hoping some one with more upstairs than me can maybe shed some light on my problem...being its doing my f#@king head in ..!!!
what I am working with ::; R33 (S2) SEDAN. (5 Speed )106,XXX Kys. 160 across all 6. ALL BLITZ :: TD05 TURBO. alloy intake. I/COOLER. twin ZONE BOOST CONTROLLER. Alloy INTAKE. pod filter . 100 Mill EXHAUST. 750 Injectors . Blitz reg.. t/ timer. ect.ect..
I am an old fart now and had 12 R33,s over my time but THIS ….  has got me ….Whenever it wants to it just shits itself "spark" wise and misses and spits and breaks down at ANY REVS..?  it CAN do this  after a cold start at tick over and run on 4 ? (sounds like it ?) it WILL come good ? ?  hit the road and 10 mins later of good get up and go.....  it falls apart AGAIN ….on boost .. or...off boost !! (running 1.2 bar...
NOW...have changed Coil Packs (new )...have changed plugs (new ) I evan bought 2 sets of plugs in case a couple were dicky ??  NOT 6 months ago had a full (POWER F/C ) TUNE !  any help on this Fella,s would be appreciated ? …..OR.....  I am in for another Power F/C tune....!!!!  cheers Nick P.
cheers my friend ...for the quick Reply !  THIS...is why I posted up !!  do you start throwing coin at an "RB" trying to snag a "WIN" when It come to this sort of problem ?  ( I am looking at CAS ? ) at this stage ?
have another R33 Coupe in the gge… may swap these units over to see IF I get lucky ?
Just finished changing ALL "vac"  lines just in case ?  thanks for your Input !
Boost leaks are frequently found hiding in metal to metal seals with gaskets (think plenum, etc).
What plug gaps?
What are the new coils? If they are rainbow coloured, they are for rainbows. We only accept new genuine Nissan, Splitfire, or substantial upgrades as proof that they should work.
State of the fuel pump? If it's dying, it can cause lean misses.
GTS BOY....  I AM over it already !!   have better things to do on a Sat than chase gremlins ??
NOT  a boost leak.  this IS DEF an electrical problem !
but in answer to your Q,s....  "yellow jacket" coils. plug gap "08". does not matter if I have the $130 a set plugs in... or....  the $35 a set in ?? the problem IS inconsistent !!! this IS what is doing my head in ??
can miss on start up...… can miss when ever it wants at any rev range. can be cruising along at 60 kys and you can feel it come on (car falls apart ) ? 5 maybe 10 mins of Shit..... and it goes away till later ?
have closed the bonnet for now & will book it in with Matty at PITTS  next week.. !! "book it" don't know how long before I can get in into him to check it out . Busy Shop by all accounts ?? Shit happens I guess.
OK GUYS..??   "YELLOW JACKET" COILS !!!
 I AM going to take a shot in the dark here and say you boys DONT like them..?
any advance on 2 Peeps saying THEY are my problem here ??   cheers.
LOL....
Love the hit rate, 9/10 misfires always relate to colourful coil packs.
My advice, stick to black OR blue.. avoid any other colour
How to fix:
  1. Buy proper coil packs, can be OEM or R35 conversion kit or Genuine Splitfire ones
  2. Remove current set
  3. Throw them into the bin
  4. Install new coilpacks
  5. Start up car
  6. Do a massive skid and post it up here
  • Like 1
Take the CAS off and turn it by hand - feel for any roughness that indicates stuffed bearing - or better still swap in a known good one.
Yellow Jackets (or red ones or anything but OEM or Splitfires) are a known weak point.
Could still be fuel supply problem.
OK BOB...totally agree with "cas" ? so have today had this out & swapped with one from my build r33 coupe in the GGE... NO change . so its not this.
Fuel delivery was done by previous owner ? don't know what pump it is but by jingo it IS a big unit ? I have a 044 In the coupe and this pump is twice the bloody size (all black ) !!
still leaning towards C/Packs ? car was doing the same but worse around 14 months ago with the stockers in...  hence the yellows . will grab a set of SPITS and throw these in and see if I get lucky ?
if not……..   tuner !!
  • Like 1
OK LADS....   I get your point !!   YES...  the car was running rough soon after I bought it and the "yellow jackets" fixed this a while back !   now back to crap again .
being an old fart at 63 …  I am looking elsewhere being I have  not got 2 years out of the yellow,s ?
not to mention...….  shit I am going though some fuel at the moment !!!!!
have put my name on a set of gen spitfires and will post up what if anything changes when fitted ??
appreciate your input lads...…….   cheers Nick P.
Bit from left field, but does the Power FC have programmable coil dwell. If set too high it will burn out the coils (personal experience).
My Wolf is set between 0.5 and 1.2 ms
No, and also with the none conventional coils from the land of dim sum and yumcha they actually misfire more with dwell and proceed to melt (ask me how I know)
OK....   Quick one lads...  I can lay my hands on a very good set of "spits"
question  ::::   they are for/off a 1996 GTR....WILL these fit my (S2) RB25DET ???
How can I tell..??   the seller Don't know ???  cheers Nick .
On 31/08/2019 at 4:33 PM, GTSBoy said:
The forum software needs an auto reply function where if an OP mentions the words "miss" or "rough" or "yellow" or "red" it will say back "It's the f**king coils!"
FYP?
  • Haha 2
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
