Hi everyone need any info on the adaptronic modular ECU, just before the end of the year my engine builder installed this ECU in my r34 it was faulty, we sent it back and they replaced it with another one, the second ECU was installed and that to was faulty to, has anyone experienced problems with this product or herd of anyone that has.
https://www.sau.com.au/forums/topic/479555-ecu-problems-on-my-r34-rb25/
racepace in Bayswater has installed both ECU's and tested both units to be faulty my entire set up is all brand new, I'm at the point where I don't think I want another one and was wondering if anyone had herd of there ECU's being faulty or giving people trouble.
Yes.....but did they test the 2nd unit BEFORE installing it? If you do Install, then test, and find it broken, you do not know if it was broken on arrival, or f**ked during/after installation. A "brand new" setup is even more likely to break something than an existing wiring setup that was known to work on another ECU.
both ecu's had different issues racepace motorsport know there stuff, they install these units all the time, but since haltech has now bought out adaptronic there seems to be issues poping up.The first ECU was running fine for five days then it had a hissy fit causing all sorts of gremlins, the second ECU had misfire issues when idling and at a certain rev range but everything else seemed to be fine, they even tried it on another car and it did the same thing.i hope someone else can enlighten me on anything they have herd on the grape vine.
Apart from the hassle I presume this is not costing you money? What has Adaptronic got to say?
A Link fan myself but Tao from Hypergear in Campbellfield has been fitting Adaptronics including to R34s with great success. Maybe give him a ring.
there has been a lot of dyno time spent solving the problems which ive been told wont cost me,but the customer service with them is a joke,there is no phone number to contact them and everything has taken way to long, they are now haltech they bought adaptronic out. racepace motorsport contacted them all last week and they didn't even have the decency to return there emails. I was going to go for a link ECU too but was convinced otherwise. Apparently the third ECU is on its way.
I have heard of someone over at performance forums having issues with a modular ecu when they first came out. The ecu was damaged when it did an auto firmware update. Was sent back to adaptech who proceeded to charge $ to repair it. Customer was not happy to say the least.
Adaptronic support used to be awesome, all my experiences with the previous gen ecu where positive, seems since the takeover things have changed unfortunately.
I asked if they would replace it with one of there haltech units they said yes, but they wouldn't refund the cost of the dyno. So it looks like number 3 ECU is on its way, what are the odds that three ECUS are faulty.
The odds are so ridiculously high that 2 adaptronics and a Haltech spontaneously explode that it is way more likely Racepace fked it up bigtime (and caused all 3 to die).
This is also obviously pretty damn unlikely, but it's more likely than 3 ECU's randomly failing instantly. ECU's breaking at all is extremely rare, and almost always due to install error.
Make sure they point to point check every wire on the ECU loom plug before they plug it in and power it up. Check all earths are earths, all powers are powers and no signal/sensor wires have 12V or some other shitty error. Just in case.
I have had dumb arse instro-eleccies kill multiple expensive controllers and flame detectors and other stuff by plugging them in, killing them, then going to the commissioning spares and grabbing another. They eventually fix the wiring problem when they run out of spares.
thanks for that, I don't think my nerves could handle it if this ecu fails,,adaptronic has double checked the unit and passed it to be fault free, it is in transit and should be here by the end of the week.i hope everything goes to plan and I can get my car back after 4 weeks, time will tell, thanks everyone for your input makes me feel a lot better.
3 hours ago, Dose Pipe Sutututu said:
Use a multimeter and check your voltage.
Old Nissans, could have a bad alternator /regulator and voltages could be through the roof and cooking electronics
That could be difficult though.....need to get the engine running first.
Sounds like the car "was" running, then after five days these unlisted issues appeared.
Gut internet mechanic feelzzzz say electrical issue.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
