so i had no idea that i need solid state relays with my fuel pumps so this was my issue the whole time with relays getting hot and pumps dying. ive now going to run these 100 Amp DC Solid State Relay with Heat Sink (windandsolar.com) thanks bk yet again.
Just now, r32-25t said:
Aftermarket industries do a solid state relay kit that has the fuse and etc built into it
cool ill check it out. thanks good mate.
Yeah I dunno about that one with PWM use though, no heatsink. Ok for just on / off control I guess.
hey ben do you know which heat sinks i need to order for the haltech relays. and when i do attach them do i use an adhesive with screws or do i just screw er down to a heat sink? cheers mate
They screw in, and ideally use computer CPU thermal paste between. Just look up on eBay for a SSR heat sink in the shape shown. It'll probably be from China if you can't get one locally.
  • Like 1
Boom, I actually found some locally at a solar place for wind towers! Thanks again for all your help Ben.
  • Like 1
Just fricken Sunk her with 30k of weight on the back. Lucky when your stuck with a skid steer on the back your really never stuck. Had to jump the skid steer off the trailer because ramps couldn’t open up it was so sunk lol. A day in my life actually quite normal lol
  • Like 2
  • Haha 1
Well much to my surprise the car made over 400whp at 14 psi. We literally did one pull and we noticed a boost leak in the Mac valve so need a new one then will try again tomorrow. I couldn’t believe it made 400 already with no timing at all, pump gas, and we didn’t even rev it past 7500.  So e85 tomorrow I jus don’t know how far to pay it being the stock motor still. My long block is almost complete but want to see what the stocker can handle. I was thinking 23 psi on e85 and 17psi on shell v power 91 octane. Cheers mates finally got to have some fun with the car again. Rb power! Thanks to Ben (bk) again for all the help throughout the roller coster!
  • Like 2
  • Thanks 1
I’d rather have my scratched up warn out r32 over any other whip out there. Even tho she has tried to kill me many times now and has cost me every dollar I’ve ever made and then some. I still know the  old girl will always be a warrior for me after a day of cutting trees.  I don’t even have words why something so average and essentially worthless(can’t take it to the grave) makes me so happy. Family first and I don’t believe in idolizing metal or anything other than  god and family. but dam I sure do enjoy fixing and learning things that may be old news to most about the old gtr.
  • Like 5
The crazy Canadians at it again, the prp trigger Picked up 40whp on install. Cars running so good figured just be done with it and enjoy it at the power it’s at. 580whp done with it for now!
  • Like 3
My wife and son are amazing individuals. Combined together it creates an experience for me that doesn’t seem real. I sometimes find myself just staring at them enjoying car meets and the people that have been brought to us from cars and I wonder how I got so lucky. She can handle a triple plate exedy at 500hp already lol. What a mate
Just been a beauty lately in the old gtr, we got it up to 25 psi now so who knows what it’s making for power but I’m damn impressed for this stock block. Last dynoed at 580 on 23 psi. Good pull in the short video below
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
