Bunging around a bit in the old garage trying to make a half descent looking catchcan/coolant over flow. Spent about 6 hours starring at it like a physco before the wheels started turning in my brain. This is what I got so far. Not so bad for the average maple leaf warrior.  Fittings for catchcan will be on the backside beside fuse box with a nice drain line ran out bottom to beside my frame where i can reach out twist a valve to let the blow by shinanigins out, cheers chaps have a fantastic day🤟
Edited by MoMnDadGTR
  • Like 1
Got the catchcan and coolant over flow done today looks ok for a Cheap garage built piece that I cut out with a skill saw lol. Cheers mates.
Started installing the meth kit last night, managed to get it mounted so I could still access the awd resevior. Battery is located on other side I figured this was a nice spot for it. Cheers mates.
  • Like 1
On 21/01/2022 at 1:31 PM, Dose Pipe Sutututu said:
Party unit installed
I call it poor mans e85. I can’t afford that stuff we have to order it by barrel around here. We have no gas pump for e85 within 1200km. Non the less I’m still going to crank it to 30psi
We are kind of lucky in parts of Australia where you can just get it off the pump.
However that duopoly has dropped down to monopoly and not sure how long it will last.
There may be a time where I'll end up with WMI as well.
  • Sad 1
  • 3 weeks later...
I fricken tell yeah mates I must have went at these lock rings for 2 hours, I used just about every product under the sun till I finally got some acetone inside the ring area/ wire brush till nothing left of brush, and lightly tapped/ smashed the hell out of them with a punch I made out of a bolt and got them loose, I got some 275’s I want to clear without rolling or touching my fenders and I hate the rear camber so I brought her up a fair bit. I like when gtr’s sit high up looks like they mean business. Anyway someone tell me what the hell these coil overs are that I have.....they say npg but that means nothing to me lol, maybe eBay I dunno I’m not a scientist. They feel great tho I must say.
  • Like 1
On 10/02/2022 at 5:45 PM, Shoota_77 said:
Yeah theyre a bastard when they dont come loose....
They look like Ohlins coil overs to me but they normally have pretty clear Ohlins branding on them.
When i was told i couldnt get them unlocked by another mate i was determined, i truely believe the acetone was the key but again im no scientist maybe they just finally decided to come free after 100 swings with hammers. i started small and the hammers kept getting bigger.
ive got the ride height 358mm from hub centre to fender in rear, and 355 in front. i mainly did this to clear some big 275/40/r17's on my regas and get rid of the nasty camber in the rear it used to have. who ever had the suspension set up before had it sagging in the rear like crazy for what ever stupid idea car handled like shizznit. once the 10 feet of snow is gone i might actually be able to try this 100k paper weight out and enjoy it with the family again.....hard starring at it everyday she wants the beans giving to her bad. will be fitting a ppg dog set soon!
On 11/02/2022 at 1:54 AM, Ben C34 said:
Acetone mixed 50:50 with auto trans fluid is awesome.
9 times out of 10 works every time!
i was this close to taking them off, buying 4 big bottle of coke and cut the tops off and leave them in there over night to free them up. glad it never got to that point. cheers mate
  • Like 1
Does anyone know where to source out dashes these days? mine has taken a turn for the worst and is bubbling quite hard(can see in picture above)?
On 21/02/2022 at 2:11 PM, Duncan said:
Pretty much every r32 dash in existence has bubbles like that. You either need to fluke a good second hand one (almost impossible), or re-cover or flock it.
thanks mate, i will try a recover.
  • 1 month later...
A little hick up with the head and now I’m back in action. I had my doubts of the new engine even working as this was my first setup self tuned motor. Might work out a dyno day to tighten it up but it’s fine for now for some family cruising. Pump with meth on 25 psi is plenty feels like 550whp.  Good to be driving the gtr everyday now. It’s a good strong setup I’m happy as hell with it now. 9:5:1 compression makes for some nice tourque but had to turn timing way down. Cheers.
  • Like 4
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
