1 minute ago, hattori hanzo said:
re exhaust, bigger is always better
See below graph of cutting the restriction out of my HKS Hi Power Silent
Will decide very soon!
awesome results man👌
yeah when i ditched my 3.5 and went to the 4" my egt's were much lower during hard driving, and recovery time was much better for egt as well. holds boost better in top end with my twins but wont notice that with that beefy Garrett, she gunna pull like a maniac either way....
  • Like 1
Update:
-Fuel tank is in with the frenchies kit and the fuel lines are completed
-cooler pipes, catch can and pod filter pipe is all painted in gloss black for that clean blackish look
Edited by oktaytrz
Wrong picture
More progress shots.
Whats left:
-Finish off the exhaust (trying to decide what muffler to use)
-Order Bosch 1650cc
-Install the hicas delete kit
-Replace all the fluids
-First Start
  • Like 1
Update
Muffler is manufactured and sent to Perth.
Next week we will be replacing all the fluids, installing the Red Optima battery and the muffler. First start is expected end of next week or early December.
On 17/11/2020 at 12:17 PM, oktaytrz said:
Is there a reason that the bov is pre intercooler and far away from your throttles ? It's also seems unnecessarily long and close to your wheel.
Bov is supposed to be mounted as close as practical to your throttle body, that's why the OEM put them where they are.
Your muffler also looks smaller than 3.5inch internally
  • Like 1
2 reasons: Placing the BOV near the turbo is to prevent compressor surge and we thought, if we ever need to go to engineering (if I get yellow stickered etc.) and plumb back, its a lot easier to plumb it back on the passenger side.
Here's another photo from another angle. its pretty far away from the wheel.
1 hour ago, BK said:
Boost control = wastegate via solenoid.
We are using the haltech boost control solenoid. I'm leaving the nitty gritty stuff in the hands of my very capable mechanic haha.
Excited for the first start up on Monday!
38 minutes ago, AgEr said:
Hey mate...just checked out this thread... nice build, your gonna love it. I got my car back a couple of weeks ago, running a similar setup. Made 450kw on pump and 550kw on e85.
Hi mate,
Thars great! How much boost you pushing through? 550kw is amazing! I'll be happy with 475kw!
Did you have to run in your engine for a bit?
48 minutes ago, oktaytrz said:
Hi mate,
My engine was already previously built.. just done the single turbo setup and some further supporting mods... 19psi on pump and 21psi on e85... if you haven't finished your exhaust, I would recommend getting an AES dump valve... easy power gains when open and it makes it sound like a monster with the flick of a switch...
  • 4 weeks later...
hey man sorry I've been away from the site for a bit. super happy for you mate. good guy even better car lol. side not I got my new rb26 finally stripped to long block and ready to ship for machining and building. ill pm you. engine looks great though man mate what a beast. the old white horse is gunna buck lol
  • Like 1
  • 5 weeks later...
UPDATE:
Its been a while.. started working FIFO so things are moving a little slow.
Still waiting for the paint prep to be completed before the respray. In the mean time we have an issue to solve which I think its the Gearbox input shaft. There's a rattling noise coming but couldnt not figure out the exact location. The tuner and my mechanic's first guess was the alternator bearing but we've started the car without the belt and the rattling was still there.
When the clutch is pressed in, the rattling goes away and the usual twin plate clutch noise comes which isn't too loud.  Due to be back home next Friday so I will be dropping the gearbox out, leave flywheel on, bolt up the bell housing/plug the starter and start the car to confirm its the gearbox.
Overall, very happy how the car turned out mechanically but I will be doing some more upgrades during the year so watch this space!
38 minutes ago, hattori hanzo said:
Did i miss something, how did it go on the dyno?
Running Tune went pretty good mate. The car drives pretty good, its just that rattling noise that I have to figure out (I put my bet towards the gearbox input shaft).
The only issue with dyno was the exhaust side of the engine bay paint lifting/burning off due to me not having a turbo beanie +reflective tape along that side of the engine bay lol. Turbo sits too close towards the engine LHS engine bay. Will fix that after the exterior paint is completed.
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
