You are correct r32 Gtr manual states front right sensor....try cleaning it, it’s very easy to take off. Just curious are your abs and 4wd light on? I just went through all this shit I’m sure we can solve it quick.
Edited by MoMnDadGTR
ok so you currently are in 2wd.  so lets get this beat. 1. make sure you have a good positive and negative connection to your battery. 2. check the main ground from battery to frame to engine mount. now that the grounds are good make sure the connection for the wheel sensor is actually plugged in. its near the drivers side strut tower in the engine bay ill take a picture for you. as far as cleaning it goes, im sure you could even just wipe it if you remove it, I used brake cleaner.
No I’m pretty old school mate no Facebook, could be a good thread for others if we fix it as well. I know when I was fixing my error codes I found lots of threads with unsolved mystery ha. Here’s a picture of abs connector for right sensor.
Okay i can confirm my one is connected. But maybe it's not a solid connection whete there may be crap contact.
I'll pull out my sensor and give it a clean after work today.
My battery was relocated to the  boot after my engine build. My awd was working perfectly before
I'll relocate the battery ground cable as it is now connected to the boot latch nut there. I might try the strut tower?
I also chased wires like you until I replaced my atessa computer in the trunk of car(atessa control unit). mine had water damage from my rear windshield sprayer leaking and was telling me codes that weren't real. check for power and continuity at that clip as well that I just posted if all else fails. hoping that connector is loose as your issue.
if it was working before I wouldn't think move the ground. be patient. my car is setup very simple(no battery relocation or anything) so it was very easy to diagnose and fix. there are some super rebutable guys on here im sure they will step in if cleaning it doesn't work. just a question what ecu are you running? ive heard and seen guys having awd problems with apexi jetro systems...if you still have a stock ecu try a different one if you can get your hands on one
https://www.gtrusablog.com/2017/05/r32-nissan-skyline-gt-r-attesa-code-1.html
this is a link for trouble shooting your error code, im 99 percent sure this will lead you to your issue...the manual has worked every time for me in solving these attesa codes. I would print it off(about 800 pages so use your works printer full r32 gtr manual) if I was you is a gtr bible!
I highly suggest trouble shooting it with the link I sent you. (It’s straight from r32 gtr manual brotha) This will rule out things quick if you know how to use a multi meter. Way better than guessing but hope it works out.....all you have to do is pull the plugs from the atessa control unit and get to work.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
