yeah it is...the third largest connector is the one your looking at, remove it and measure for continuity between terminals 13,14,15,16,17,18,19,20 between .8 and 2.2, the terminals you are focusing on are in pattern. remember you are measuring the harness side not the atessa control unit side. if you have continuity between the connector terminals you need a new control unit. if you don't have continuity you need to measure resistance at terminals 1 2 3 and 4.  this will narrow it down for you without doing any wrenching at all.
@MoMnDadGTR
So this is my results
13 though to 20 is no continuity
So I tested 1 2 3 4
2 and 4 gives me 130
3 And 4 is contunious
2 and 3 gives me 115
I'm so confused how should the numbers be
You're not supposed to test all of them to all of them. The original linked document clearly says check 13-14, 15-16, 17-18, 19-20.
Expected resistance is between 800 - 2000 ohm.
You do not do this with the multimeter set to continuity. You do it with it set to the appropriate resistance range. Which will either be 2k or 20 k. Try 20k first, as raw accuracy is not important here.
If the circuit is open (infinite resistance) then you have a broken wire, dud sensor, something like that. If the resistance is drastically low, it's either a wiring short or a dud sensor.
You can see the difference between harness faults and sensor faults by measuring at the sensors, as shown in the diagnosis tree.
  • Like 1
@GTSBoy
I just want to clarify I have tested
13 to 14 15 to 16 and so on with my tester. There is no continuity.
So my next step would be to test the terminal 1 2 3 and 4. Can you confirm this is correct
There's not supposed to be "continuity" in the sense of a short circuit. The resistance across those pairs of wires is supposed to be between 800 and 2200 ohms. As measured with the multimeter set to the appropriate resistance scale, probably 20k ohms.
29 minutes ago, Semih_Ozdemir said:
The meter I've got is a fluke multimeter.
It hasn't got the setting to change over to 20k ohm etc.
This cannot be true. The very definition of a multimeter means that it can measure resistance. Fluke is the best brand out there. It is not possible that it doesn't have it.
The red arrow shows you the resistance mode. Flukes are autoranging, so you don't even need to select the 20k range yourself. It will do it for you.
correct the multi meter has to have the setting on it looks like a horse shoe. I also can add that when testing for resistance make dam sure you have a good connection in the terminal with a nice sharp end, sometimes you can tie a paper clip to the end of your multimeter probe to get a better connection in the terminal. this is sounding like bad ground, broken wire, something to do with the relocation I believe. let us know when you have done the resistance test on terminals 13-20. then we can narrow down if you need a new control unit or if we need to continue testing
ive always stayed away from relocations and what not to keep diagnostics easier and what not just keeping a simple fast platform. I do feel once the multimeter and you become friends your gunna solve this issue quick.
Okay @GTSBoy I've got a fluke clamp meter. My bad. It only measures continuity and not resistance eith a scale.
@MoMnDadGTR
I've got 2 sensors of a mate. I'm just going to replace the front right sensor and see if that fixes my issue
No. Swaptronics is the last resort, not the first.
A useful multimeter is $10 at Jaycar.
What model? I've never seen one that doesn't do resistance, current, volts, etc.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
