Hi, I bought an r32 gtst almost a year back and ive been fixing all the little bits and pieces to get it to the stage of a road worthy. The guy i bought it off said its got an rb25det, The motor is N/A at the moment but im not sure if its de or det. The head is stamped 75T and so is the block. Any way of telling if it was originally turbo'd. New to the skylines and tryna learn. Thanks
sorry if this is in the wrong place.
https://www.sau.com.au/forums/topic/480000-not-sure-if-my-rb25-is-a-det-or-de/
Well, what it originally left the factory with is stamped on the chassis plate on the firewall. R32 GTST came with rb20det not rb25det, although some late r32 gts came with rb25de no t.
But I guess you are asking if you have an rb25det motor with a turbo removed, or an rb25de. One way to tell should be a compression test as the rb25det will have lower compression, not sure other certain ways because it seems some rb25de blocks had plugged ports for the oil feed and oil return instead of nothing at all (although, no oil ports would confirm rb25de)
Quick search on here suggests 75T was the casting number for both rb25de and rb25det from R33 gtst, so that doesn't help.
This is your best bet i can think of...That red circle is your turbo oil drain.  if in that area on your block is a blank/does not exists then it is 100% a de block. If this spot on your block has any kind plug of bolt or block off that goes into a hole, then its a turbo block that plugged up.
Na sorry mate, have a de block here drilled and tapped for turbo oil return with a plug in it, so thats not necessarily true.
15 hours ago, Dil-Dog said:
Damn bro..... i only have experience with neo’s. That must be a series 1/2 specific thing then. My 25de neo and my friends 25de neo is a blank in that location. good looking out though. @Rusty Nuts
It is weird they bothered drilling and tapping then plugging it, but that's what they did.
What's even stranger is they did the same on rb30 blocks. Good on them for helping us out though !
  • Like 1
The blocks would have been all turbo spec on the production line, then some bean counter said "hey we can save some yen" and got a bonus.
    • Sane enough. Remove the roof liner, because the acid will go everywhere.
    • Thanks guys, I really appreciate the help and experienced opinions.  I have spent a lot of my life working on boats so I'm pretty good with fibreglass. I'll take everybody's advice in here;  I'll cut a little more of the 2nd layer away as it's a bit crunchy rust and also it's sitting high now. Then I'll wire brush it all a bit to get off anything loose, then I'll soak the bejesus out of it all in rust converter. I'll make sure to get a little hose piece and feed it into all the holes and gaps between the roof layers. Then I'll fibreglass up the holes.  Then I'll get a pallet of filler and mix it with 3 buckets of hardener and hope that is enough to build up the roof corner.  Does that sound sane? Is one type of filler better than others for this?
    • My goals for it atm are to get it registered, respray and some mild power gains eventually... I picked up the car from an elderly gentleman near the border of NSW and VIC, its honestly a bit rough and looks like its been driven on a farm (because there was so much dirt underneath). Last week I dropped the subframe and emptied the old fuel out + added a new fuel pump (think the old one went bad from old fuel). Now I'm onto fixing a coolant leak at the rear of the engine + adding a new radiator as the old one is corroded. After that i have a new bumper, coils (as the old were leaking) and lots more
    • Welcome buddy! Plenty on here and YouTube. What are your plans for it? Good luck with the Rwc and Rego bud!
    • Love this so much! Please post a photo when you have a bike on the trailer.  I was a little bit worried about having a tow bar on the Skyline, but having it hidden behind the number plate is genius
