Got my quote for a cam and stuff install.
Waiting for workshop time now.
oztrack-camshaft-kits-with-remote-custom-tuning-afm-delete-removal-cam-upgrade-online-leaders-in-ls-auto-part-tire_709_250x250@2x.jpg.4657e7a70c1e18cef044f9f6ef46454a.jpg
Cannot decide on which one though.
Oztrack recommend the LSV or HP3.
They recommend that LSV would suit the car as is, but the HP3 has headroom for intake manifold and head work in the future.
LSV idles smooth and comes on fairly quick.
The HP3 is fairly choppy (I love the sound of a lumpy cam) but still ok for the stock converter.
Both are a big improvement over the current cam, lots of gains in torque and between 30-50kw up high.
I'm leaning towards the HP3 maily because of #lumpyloapylols, the 3.9 diff gears should "hopefully" help it get up into the cam without to much delay.
Streetability for both are apparently good.
Hmmmm
In other news: my fears of a highstall and not locking up in the auto are unfounded, soooo, if I do go the bigger cam, a high stall converter will be the next mod.
Now all I need is that WSID opens soon so I can do a pre and post run.
LOL, f**king Covid spoiling all my fun.
Hmmmm
LSV out of those choices. THe LS1 doesnt need / beneift from such a large exhaust duration split.
choppy idle can be tuned to suit.
glad you have seen the light regarding conveters!
  • Thanks 1
You are going to run into the exact same problem I did re: Cams and the rest of the system being able to supply the air the cam wants.
Be aware!
If you are going to keep stock heads (and not be super obsessive about checking springs, etc etc, want something that will be put in and forget) then the LSV is the smart choice.
The "power" category of that chart does require additional mods to unlock the said power. Drivability is easier in an auto which you have on your side. Cam surge is just shit to live with. Power under the curve is still a thing in V8 land.
  • Thanks 1
Be aware!
I've been looking at heads and an intake, the intake is relatively cheapish, the heads are costly, sooooo
Thanks all for the information, I'll have them throw in the LSV with the all the other snot they install at the same time.
It is diminishing gains (especially value for money wise) when going further than just a cam / spring job.  As kinkstaah said area under the curve is still important, and going to a larger can will hurt economy also
  • Thanks 1
Car goes in tomorrow.
The guy recommend trunion bushing kit?
They look like solid brass vs roller.
Like this > https://vcmstore.com.au/products/ls-rocker-trunnion-upgrade-kit
Thoughts
Thoughts
Wrong part number and link for nitrous kit
  • Haha 1
Thoughts
I vote no. I would be more concerned the trunnion galling when solid, considering the way they are lubricated is "hoping the oil splashing around happens to land there", push rod style! .
  • Thanks 1
Its less choppy than mine. That said it probably drives right, and doesn't shake you and your passengers at idle in the seat (is kinda cool tho) and is the right cam! Which one did you go in the end?
LSV
It does do a "little" shimmy at idle in neutral, once in drive it just squats down a bit harder on the brake.
Thats really what you want man.. Idle shake is cool and all until you have anyone in the car that doesn't think its great and it quickly becomes shitty.
That cam looks the goods. Was the dyno run locked?
So, after taking the Mrs for a cruise today (Robertson pie shop, long way there, long way home) I'm definitely looking at those interceptor copies in silver, with caps of course, #fullbogan
17 x 8 + 42 for the front
17 x 9 + 48 for the rear
Tyres will be Hankook RS4, cheap but good.
235/45 front and 255/40 rear
Rollin' on 19" rims and rubber band tyres is arse on anything other than dead flat and smooth highways.
I'm just waiting on a shipping quote.
In other, Mrs related news, she wants me to put the pacemaker rear muffler back on, doing a dollar ten on the highway with 3.9 gears is to noisy for her to sleep.....LOL.
Meh, things you do..
I'm also still looking for 2 interceptors, 15 x 7 which I will shod with some Micky T's for LOL's at WSID.
I believe the converter was locked.
But, my speedo reading is way out now, I believe they f**ked up the calibration it had for the 3.9 diff when they played with rhe tune.
GPS reads 80, speedo reads 100.
How and if this effects anything I have no clue, apart from me driving like Miss Daisy.
I'll ring them tomorrow to get it fixed.
I was doing what I thought was 100 in a 100 zone and everyone was passing me, I got the Mrs to get google maps up and to my dismay I was doing 80.
    • Please use a modern ECU. PowerFC with the Nintendo Gameboy controller is horrible. It's not 2005 anymore.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
