On 25/01/2022 at 7:31 PM, GTSBoy said:
Just extend the reverse cowl in perspex up over the windscreen and roof so it sucks instead of blows. Can't look any worse than it does now!
Yeah.......it's going soon
It's not the first time that my good idea has turned to stupid
And it won't be the last
  • Like 1
On 25/01/2022 at 7:18 PM, mlr said:
Funny story
The above added ventilation has increased my IAT by 5°c and my coolant, which typically sits at about 90°c, was at 97°c
After doing some hasty wool tuft testing, it seems kow when at speeds over 40kph the reverse cowl works very well at sucking in air, pressurising the engine compartment, and reducing the efficiency of radiator stack quite well
I assume my trans temps would have raised as well as the air to oil trans coolers efficiency would have been effected as well
So, lucky I have the spare bonnet that will be getting the frame modified to give me some clearance
Marks bad idea #943: Fitting a reverse cowl scoop
LOL 🤯
lol pics of driving around with wools stuck to the car or it didn't happen :)
  • Like 1
What else did you think it'd do?
It'll let heat OUT of the engine bay when you're idling/sitting but that is about it, at speed the pressure will force its way in.
The vents to reduce heat are ones you see on GT3 style cars.
image.thumb.png.4415c256dbdf3b3f3093a9f54dc9237a.pngimage.thumb.png.dccc96a6a11167ab734759400b249ef7.png
The concept is you provide a good ol duct for the radiator at speed for it to the immediately exit, the reverse cowl would probably work if there was a duct from your radiator directly to it and out of the car but fitting that could be.... problematic....
  • Like 1
I wish they made a bonnet for mine like the vented one I had on the 33, that worked a treat
As for the the cowl sucking in air, yeah I new it wound do it, but I didn't think it would effect the IAT and coolant temp so much, with only the  5x 100mm ○ holes it wasn't noticeable, but after the chop chop, well, it's farked
After a drive today, the IAT got up to 70°, that is a 20° increase to what it was 2 days ago doing the same run, and the coolant never went lower than 97°c
I checked the WTA intercooler pump, and the thermo fans because I thought that I may have invertantly unplugged something, but no, it was all because of stupid
Luckly the car is going into the paint shop next week to unfarkithe bonnet
#Duncan the "wool tuft" was actually fluoro pink string line, it was magnificent 👌
On 27/01/2022 at 6:12 PM, robbo_rb180 said:
how does it drive now with the ratio change?
It's noticable when cruising, I haven't launched or laid 11's yet though
The car is going in to get the trans shift points played with to suit the new gears next Monday
Monday afternoon will possibly have a launch and skid involved.....or 2......for scientific research purposes of course
I'm going on a 600km Hwy run on Thursday, I'm curious if there will be a noticable difference in L/ 100 km, not that it's important, but currently it's around 11L=100 km on the Hwy ATM
Hopefully hit WSID on 02 Feb, seeing if it helps the 60' a bit is the big one I'm looking at
  • Like 3
That drive will be good to see economy.
Need videos of scientific testing, I'm sure it will be conducted in a controlled environment with safety equipment........
Hopefully get that 11, take an esky with a few bags of ice to help cool it in the lanes.
  • Like 1
Lowered engine mounts are on their way
TM011-TUFF-MOUNTS-Engine-mount-VT-VZ-Commodore-LS1-WEB.thumb.jpg.d8dc46b7fa8cab803b24a238570a84b5.jpg
So with the bonnet frame clearanced and the lowered mounts (13mm lower than stock) but with a 5mm spacer so the headers clear the K Frame, I'll have heaps of room under the bonnet for the thermal spacers and underbonnet insulation without have speed holes in the bonnet
In other news I recovered my Harley seat with some marine grade vinyl after thinking that tying on a steel tool box to it to take some tools over to a mates house was a good idea, it wasn't and the seat ended up with a big tear
It wouldn't win any prizes but at least it doesn't have a hole anymore
  • Like 1
On 01/02/2022 at 9:31 AM, Kinkstaah said:
Poly mounts on a LS1 should be... interesting.... for that 70's muscle car driving a clothes dryer feel at the lights
I hope so, LOL 😆
Could you explain this to me? I'm not sure how to picture driving a clothes dryer. A washing machine maybe, but not a clothes dryer.
Poly mounts are stiffer, so more vibration from a rumbly V8 on idle?
  • Like 1
Effectively the same, but a spin dryer was what I was thinking of. I own a machine that doubles as a dryer and it vibrates considerably more on its dry cycle compared to its wash cycle lol.
I have OEM Nissan mounts in my R34, and I feel the LS rumble noticeably when stopped through the seats, _BUT_ I believe I have a larger cam than @mlr. My only other experience were poly mounts with a SR20DET which definitely felt like sitting ontop of a washing machine/jackhammer at the lights, i.e it was shit.
  • Thanks 1
Hwy fuel economy, basically cruise control set at 100- 110kph for 99% of the trip
Holsworthy - Goulburn - Canberra- Goulburn- Holsworthy = Averaged out at 9.5L/100 Km
No drags last night because of rain
In orher news: My thermal spacers and blanket arrived yesterday and my lowered tuff mounts arrived today
  • Like 1
 got to be happy with that for an old v8 😛
  • Like 1
The car is a great place to be in cruising along, inside the cabin you can barely hear the growl of the engine
  • Like 1
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
