On 25/01/2022 at 7:31 PM, GTSBoy said:
Just extend the reverse cowl in perspex up over the windscreen and roof so it sucks instead of blows. Can't look any worse than it does now!
Yeah.......it's going soon
It's not the first time that my good idea has turned to stupid
And it won't be the last
  • Like 1
On 25/01/2022 at 7:18 PM, mlr said:
Funny story
The above added ventilation has increased my IAT by 5°c and my coolant, which typically sits at about 90°c, was at 97°c
After doing some hasty wool tuft testing, it seems kow when at speeds over 40kph the reverse cowl works very well at sucking in air, pressurising the engine compartment, and reducing the efficiency of radiator stack quite well
I assume my trans temps would have raised as well as the air to oil trans coolers efficiency would have been effected as well
So, lucky I have the spare bonnet that will be getting the frame modified to give me some clearance
Marks bad idea #943: Fitting a reverse cowl scoop
LOL 🤯
lol pics of driving around with wools stuck to the car or it didn't happen :)
  • Like 1
What else did you think it'd do?
It'll let heat OUT of the engine bay when you're idling/sitting but that is about it, at speed the pressure will force its way in.
The vents to reduce heat are ones you see on GT3 style cars.
image.thumb.png.4415c256dbdf3b3f3093a9f54dc9237a.pngimage.thumb.png.dccc96a6a11167ab734759400b249ef7.png
The concept is you provide a good ol duct for the radiator at speed for it to the immediately exit, the reverse cowl would probably work if there was a duct from your radiator directly to it and out of the car but fitting that could be.... problematic....
  • Like 1
I wish they made a bonnet for mine like the vented one I had on the 33, that worked a treat
As for the the cowl sucking in air, yeah I new it wound do it, but I didn't think it would effect the IAT and coolant temp so much, with only the  5x 100mm ○ holes it wasn't noticeable, but after the chop chop, well, it's farked
After a drive today, the IAT got up to 70°, that is a 20° increase to what it was 2 days ago doing the same run, and the coolant never went lower than 97°c
I checked the WTA intercooler pump, and the thermo fans because I thought that I may have invertantly unplugged something, but no, it was all because of stupid
Luckly the car is going into the paint shop next week to unfarkithe bonnet
#Duncan the "wool tuft" was actually fluoro pink string line, it was magnificent 👌
On 27/01/2022 at 6:12 PM, robbo_rb180 said:
how does it drive now with the ratio change?
It's noticable when cruising, I haven't launched or laid 11's yet though
The car is going in to get the trans shift points played with to suit the new gears next Monday
Monday afternoon will possibly have a launch and skid involved.....or 2......for scientific research purposes of course
I'm going on a 600km Hwy run on Thursday, I'm curious if there will be a noticable difference in L/ 100 km, not that it's important, but currently it's around 11L=100 km on the Hwy ATM
Hopefully hit WSID on 02 Feb, seeing if it helps the 60' a bit is the big one I'm looking at
  • Like 3
That drive will be good to see economy.
Need videos of scientific testing, I'm sure it will be conducted in a controlled environment with safety equipment........
Hopefully get that 11, take an esky with a few bags of ice to help cool it in the lanes.
  • Like 1
Lowered engine mounts are on their way
TM011-TUFF-MOUNTS-Engine-mount-VT-VZ-Commodore-LS1-WEB.thumb.jpg.d8dc46b7fa8cab803b24a238570a84b5.jpg
So with the bonnet frame clearanced and the lowered mounts (13mm lower than stock) but with a 5mm spacer so the headers clear the K Frame, I'll have heaps of room under the bonnet for the thermal spacers and underbonnet insulation without have speed holes in the bonnet
In other news I recovered my Harley seat with some marine grade vinyl after thinking that tying on a steel tool box to it to take some tools over to a mates house was a good idea, it wasn't and the seat ended up with a big tear
It wouldn't win any prizes but at least it doesn't have a hole anymore
  • Like 1
On 01/02/2022 at 9:31 AM, Kinkstaah said:
Poly mounts on a LS1 should be... interesting.... for that 70's muscle car driving a clothes dryer feel at the lights
I hope so, LOL 😆
Could you explain this to me? I'm not sure how to picture driving a clothes dryer. A washing machine maybe, but not a clothes dryer.
Poly mounts are stiffer, so more vibration from a rumbly V8 on idle?
  • Like 1
Effectively the same, but a spin dryer was what I was thinking of. I own a machine that doubles as a dryer and it vibrates considerably more on its dry cycle compared to its wash cycle lol.
I have OEM Nissan mounts in my R34, and I feel the LS rumble noticeably when stopped through the seats, _BUT_ I believe I have a larger cam than @mlr. My only other experience were poly mounts with a SR20DET which definitely felt like sitting ontop of a washing machine/jackhammer at the lights, i.e it was shit.
  • Thanks 1
Hwy fuel economy, basically cruise control set at 100- 110kph for 99% of the trip
Holsworthy - Goulburn - Canberra- Goulburn- Holsworthy = Averaged out at 9.5L/100 Km
No drags last night because of rain
In orher news: My thermal spacers and blanket arrived yesterday and my lowered tuff mounts arrived today
  • Like 1
 got to be happy with that for an old v8 😛
  • Like 1
The car is a great place to be in cruising along, inside the cabin you can barely hear the growl of the engine
  • Like 1
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
