On 9/10/2020 at 11:06 PM, Tobz said:
Also would be interested in your voltage values for the fuel level
I still haven't gotten around to sorting this yet, but I will soon.
I didn't think I'd have any speed bumps other then the charge light =/ When I get around to doing this job, I'll pull the dash out, take the car for a drive and see what else breaks.
I'll post up the fuel level vs voltage table that I'll build as well when its done.
So this is what I’ve worked out that you need to sort if you replace the dash;
battery light
central locking control unit
interior light (I think the door light on the dash powers the interior light when you open and close the doors.
speed sensor
then the wires you need to add to connect to the new dash are the indicators, hand brake, high beam
Edited by Tobz
  • 5 weeks later...
I used the fuel sender value I found on HERE
I really didnt want to pull the sender out at the time. I'm curious to see your readings
On a side note you may need the Haltech GPS module to clock the speed correct for the IC-7. The speedo signal goes to the OEM cluster before the ECU which makes it a pain to get the speed correct.
  • Like 1
battery light
speed sensor
I have my IC-7 installed and I can confirm the interior lighting works w/o original dash
The IC-7 can display the battery voltage/set alarms so there's no need to wire for the light
And annoyingly, the IQ3 dash GPS is not available on the Haltech CAN, so you end up needing 2 GPS receivers :/
I have an R34, may be different?
And i think the battery light is wired in as an exciter for the alternator? Without it the alternator may not be charging your battery properly?
On my car we took the speed sensor wires from the Gearbox and then and spliced them into the wires going to the ecu, so we bypassed the dash.
Sorry just to confirm i used a GPS speed app on my phone to work out what 60kph is.
Then in the haltech ecu I went to the speed sensor page and hit the calibrate button when i was doing a constant 60kph according to the gps app.
Once that was done it was all calibrated and perfect :)
1 minute ago, Tobz said:
Just needed to calibrate it, which was pretty easy, got my phone out, did a constant 60kph on a straight road, hit the calibrate button, and now its perfect
Copy. So just the signal to the proper pin (53 on R33) at the ECU then ground (any ground)? Does the R34 VSS go to the dash first like the R33?
I may try this and see what happens. I really didn't want to GPS module for the possibility of it dropping out.
R34 GTT went to to the dash first. There are two sensor wires that leave the gearbox near the front cross member on the driver side. I cut those, then wired in some new wires, went up through the gearbox shifter and routed them to the ECU. There are two wires, they are non polarised so it doesnt matter which way they are wired. There is no ground.
Also sorry my interior light still works, but doesnt automatically turn on when u open the door. i think it ran off the door open light on the dash
Ok. I will try to mess with this over the weekend. I will still install the GPS just in case I have troubles.
So re-wire directly to the ECU, one wire to VSS pin 53 and one to 12v power on the ECU
there should be two pins for the speed sensor on the ECU.....
OK for the R33, 7 is the Tacho speed signal and 53 is the vehicle speed sensor. is the tac signal the 2nd pin? that the only other pin  i assume get spliced
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
