1 minute ago, Lamsr334door said:
Interior looks amazing dude, the dash suits it so well, I've been tossing up with either an IC-7, microtech or AIM  dash, also where did you get the AC control unit moulding from, I like that location
overall was this an easy install and would you recommend it ? if yes could u do a quick run down of all the wires u spliced into n stuff, i want a dash for my 33 but I'm lazy as f**k with wiring ( do it every day with work ) and can never be bothered wiring shit on my own car haha
Lol i get it man. Its like all the landscapers with $h!tțy yards.
It took a bit to figure out the wiring and what all was need as the speedo converts some signals. Overall it was an easy task once it was all clear.
Scan thru this post. I posted a link on a how-to for the fuel sender.
Speedo wiring to the aftermarket calibrator/ charge light info is in here as well
You will have to wire the hi-beams/turn signals/e-brake/parking light directly to the units connectors (IC-7). I took pics of the back of my oem cluster which is used to find which wires I needed to t-tap into. Sorry I dont remember the colors of them.
The HVAC/shifter surround is from Garage Yoshida
  • Like 1
  • Thanks 1
I was curious  on wiring the the signals, hi beams, e brake, You just take a wire from the back of ic7 and then tap it directly into the plug off the cluster? I briefly tried it and it wouldnt illuminate on the ic7 dash, Is there something im missing?
Yes. Run the signal wires for those to the pins outline in the IC-7 instructions.
Make sure to push the pin lock open on the plug so the pins can seat all the way in.
  • Thanks 1
exactly, you literally just tap the correct wires at the dash because they all operate the way the dash requires, including the handbrake. (potentially excluding speed and fuel level sender as discussed above)
  • Thanks 1
Ok that was the issue wasn’t seated all the way, I Ran a test wire through but I can’t seem to find the the little deustch connectors, did the ic7 come with them or am I going crazy ?
  • Like 1
I’m assuming you’re referring the battery light (wire) on the stock cluster ?
The battery light in the dash cluster is the charge light. Have a read through the whole thread, it's been covered off already.
  • Like 1
On 10/20/2020 at 4:47 PM, SLVRBAKSLPZ said:
I used the fuel sender value I found on HERE
I really didnt want to pull the sender out at the time. I'm curious to see your readings
On a side note you may need the Haltech GPS module to clock the speed correct for the IC-7. The speedo signal goes to the OEM cluster before the ECU which makes it a pain to get the speed correct.
So for the fuel level, it’s literally one wire to get it to work and it should self ground from the pump? No Matter how I configure it it does not work correctly anyone have any ideas ? I’m using the far left wire in picture for the fuel gauge
Gonna need the fuel level sender conditioner. Haltech makes one
On Haltech ECUs the signal wire goes into one of the AVI inputs
2 hours ago, Murray_Calavera said:
Haltech have just updated the IC7, you can feed the raw fuel level signal straight into the dash now if that's easier.
God damn it.... that would have been helpful when I did mine. At least I can swap it now and free up an avi for the haltech for the oil temp sensor
  • Like 1
Just now, R324u said:
Yes I’ve tried to put it through the dash, just as the update but it does not do anything for me, idk I called haltech and they really didn’t help much either. Gonna have to keep messing with it
I wired mine up about an hr ago and it worked..
The the red/gray wire for signal (i used pin 18
The teal wire is the ground for pin 30
Make sure to select the correct channel for the AVI you used. And use 90-0 ohm
The you select the spot on your dash for the fuel level choose the AVI, not fuel level.
You still are required to adjust the voltage.
  • Like 1
Rt. I will keep both hooked up and see with one reads the most accurate. As of now I feel like the oem to dash is better.
My fuel level conditioner does a weird thing where it reads high then levels out after about 30secs. Im sure its something I can adjust in the ecu. The oem just reads the level instantly
Be interesting to see if tue oem to dash bounces around more while driving
I will investigate soon. I also have to see if my voltage setting are correct as well once I fill up.
  • Like 1
I was able to make some progress on it  last night by doing this just saw your post., I had to set the dash to default, what car are you using this on an r32?  I’m using pin 21/ 30 for the ground but those wire colors  you mentioned don’t match up to what I have so I’m guessing you have a diff chassis
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
