Hello. Its been a couple of years since I've been here. I own a 1990 GTR. Originally the car was light blue, hence the name Smurfette. It has since received a new collour changing paint job and the power goals have changed also. Perhaps she will be renamed to Evil Smurfette.
After ma y years of ownership and various bolt on upgrades, the car is fine in a shop getting a proper rebuild.
Firstly, all the leaks, seals, lights, rust spots are being rectified. While that is being done and the engine is out, we will do  spool 3.4L stroker, PRP billet caps/brace upgrade. Head will also recieve an upgrade of parts and some port work.
Car will run on 98ron on a day to day basis with e85 for track days. Intan pump will feed a surge tank which will feed 2000cc injectors.
While the engine is being run in and I learn how to drive, drive train will remain untouched accept for a twin plate clutch. Later on i will get a PPG 5 speed and look to upgrade the drive shift, axles and diffs as needed.
For induction, I am leaning towards a twin G25-660 setup. It will be a squeeze but the result will be a more factory look and more the enligh power to have vreat fun in with the car. Does anyone know of any gtrs where thats been done?
I will keep the updates coming as often as I can. IMG_1806.JPG.314a4ec010c0669ad9c980c4503d1d7a.JPG
  • Like 1
https://www.sau.com.au/forums/topic/480752-smurfette-r32-gtr-build/
I like it. I'm not normally a fan of colour flip paint, but that looks like a good choice for an R32.
I think your choice of wheels is going to become critical to how it ends up looking. Something black would be an obvious choice, but I'm sure something in a metallic colour (not a shiny silver) will also work.
I agree, the wheels can make or break a look. I'm going to keep the wheels that are on it now. 17x10.5 very light weight. Very dark grey matt finish. I also removed the rear spoiler.
Trying to add another image of the car but not having much luck.
Small update.
In the process of ordering the spool 3.4l bottom end.
9.5 compression ratio
Upgraded wrist pins and bolts
Billet main caps and brace.
Will have allot of rb26 and rb30 gear for sale in the next few days.
  • 1 month later...
Things are moving slower then expected. Had a months delay on rust repair. But if all goes well, the car is getting picked up this week to get the rust repaired and engine bay repainted.
On the parts side, I have managed to secure all the interior parts I was missing. Plus:
Virgin RD28 block.
PRP block brace with integrated caps
A head which has been ported, polished, +1mm valves. 260/10.25 cams.
Will be going 3.2 instead of 3.4 to limit bearing wear due to sideload of long stroke.
  • Like 1
Virgin RD28 block.
  • Like 1
This is the inspiration for my build. Garage Bomber gtr. This thing made 760hp at the wheels in 1999 and ran 9.77@145mph. I still think its one of the best finished gtrs.
Edited by khezz
  • Like 5
Big development overnight. I am now the owner of a JHH 3.2L bottom end.
Nitto 3.2L stroker
9.0 to 1 comp ratio
Darton sleeves
Block half grout filled
JHH billet main caps
JHH block brace and AWD adaptor
+625 head and rod bolts
Uograded pins
Bottom end is definitely not the weakest link anymore.
  • Like 4
  • 1 month later...
Your engine looks to be a bloody nice bit of kit.  Should be super strong.
What are the rust repairs?  Sills?  Wasn't that what it went in for when you originally got it painted or was those rust repairs just the visible parts that you've had painted and this is now all under the skin?
There are some rust spots in the engine bay. I am going to get them repaired properly (new panels if needed). Plus going to add allot more weld around the points that take the punishment of 1000hp launches.
This was noticed a couple of years ago but due to various issues, the engine never came out and the whole project was put on hold.
Now that the car is all apart, work can be done properly.
Once all the repair and strengthening work is done, we will repaint underneath to stop rust coming back and paint the engine bay to match exterior colour.
Edited by khezz
  • Like 1
  • 3 months later...
Well it's been a while sins my last update. The 3.2L bottom end is all finished and with me. Body is just about done to. Engine bay will be the same colour as the exterior of the car. All going well, ill be at Cootamundra and Bathurst at the end of the year.
  • Like 8
  • 1 month later...
Starting to come together. Last of the panels have arrived. Shouldn't be long now. Looks like I'll be changing my turbo choice from G42-1450 to a Precision gen2 7685. By all accounts it will get me my power goals but with better street drivability.
  • Like 2
So I am waiting for an invoice for an OS88 gearbox and OS quad plate clutch. I know the plan was to go for dog box but I just couldn't say no. Does any one know if shift cut can be easily installed after the gearbox has been installed or should I try and do it now?
If you want to do it properly you need to install a gear position sensor BEFORE the box goes in. You’ll then need a strain gauge. Depending on the strain gauge used factor in around $2500 to do this.
Here are a couple photos of the sensor I used on the OS88.
The strain gauge was the “Motorsport systems” item. Same as what they use in V8 Supercars. It’s about $1500, made in Sydney.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
