Hi guys I have a v35 coupe 2004 auto.
I'm looking for a project in the near future, there's a few options I'm thinking of and one of them is engine swapping my v35...
I want to slap another nissan engine in !
I thought a vk45 or a vq30det would be cool.. and yes I know they will be huge projects but that's why they're called projects... I got a few thousand to play with but not moon money if that makes sense !
Any ideas/help/ advice on either would be appreciated !
Cheers team
https://www.sau.com.au/forums/topic/480883-v35-coupe-engine-swap/
VQ30DET makes no sense. 1. It's older, so you won't get it legal. 2. It's just another bloody VQ engine. Better off just slapping turbos onto the VQ35 you have.
VK makes sense, because V6s are gross, and V8s are not. You should work out the max capacity you can have by the NCOP rules and see if you shouldn't be planning on the largest VK (the 56). I'd suggest it should be feasible, because you can drop LS engines into these things, and they are larger capacity.
If going V8, then smaller/lighter/better makes more sense. Smaller, lighter and better than the VK, I mean. That means LS. I would be looking for an LS2 or LS3 myself. All alloy, narrower, easier to fit. Remember that the VQ you have is a 60° engine. The VK is a 90° engine and its heads are quite wide.
Cheers mate ! True about the vq30 too... would like to see a vk45 more than an LS I think itll be more cool/different.
The number of thousands to do any project like this are in the realm of 10,000's, not 1,000's..
Sadly a V35 engine swap (what do you plan to do with the auto gearbox?) is really less feasible than getting something more suited to the task.
VK56 swaps have been done, but I believe they are extremely tight in that engine bay.
https://g35driver.com/forums/engine-drivetrain-forced-induction/455271-04-coupe-vk56-engine-swap-build-8.html
People tend to go the LS1 route though, easier, stronger, more upgrade options, availability of parts.
also seems like a lot of people start the vk** swap and never finish it as I couldn't find many running examples only one I've seen in person is the MCA 370z and that is never going to be a street car again.
If wanting V8 the LS* swap is the way, can even use the CD009 6 speed these days that way really should only need engine mounts. Other thing may be a honda 4 cylinder of some variety pending year to meet emissions but thats a small engine in a barge.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
