Hi guys I have a v35 coupe 2004 auto.
I'm looking for a project in the near future, there's a few options I'm thinking of and one of them is engine swapping my v35...
I want to slap another nissan engine in !
I thought a vk45 or a vq30det would be cool.. and yes I know they will be huge projects but that's why they're called projects... I got a few thousand to play with but not moon money if that makes sense !
Any ideas/help/ advice on either would be appreciated !
Cheers team
https://www.sau.com.au/forums/topic/480883-v35-coupe-engine-swap/
VQ30DET makes no sense. 1. It's older, so you won't get it legal. 2. It's just another bloody VQ engine. Better off just slapping turbos onto the VQ35 you have.
VK makes sense, because V6s are gross, and V8s are not. You should work out the max capacity you can have by the NCOP rules and see if you shouldn't be planning on the largest VK (the 56). I'd suggest it should be feasible, because you can drop LS engines into these things, and they are larger capacity.
If going V8, then smaller/lighter/better makes more sense. Smaller, lighter and better than the VK, I mean. That means LS. I would be looking for an LS2 or LS3 myself. All alloy, narrower, easier to fit. Remember that the VQ you have is a 60° engine. The VK is a 90° engine and its heads are quite wide.
Cheers mate ! True about the vq30 too... would like to see a vk45 more than an LS I think itll be more cool/different.
The number of thousands to do any project like this are in the realm of 10,000's, not 1,000's..
Sadly a V35 engine swap (what do you plan to do with the auto gearbox?) is really less feasible than getting something more suited to the task.
VK56 swaps have been done, but I believe they are extremely tight in that engine bay.
https://g35driver.com/forums/engine-drivetrain-forced-induction/455271-04-coupe-vk56-engine-swap-build-8.html
People tend to go the LS1 route though, easier, stronger, more upgrade options, availability of parts.
also seems like a lot of people start the vk** swap and never finish it as I couldn't find many running examples only one I've seen in person is the MCA 370z and that is never going to be a street car again.
If wanting V8 the LS* swap is the way, can even use the CD009 6 speed these days that way really should only need engine mounts. Other thing may be a honda 4 cylinder of some variety pending year to meet emissions but thats a small engine in a barge.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
