Hi guys I have a v35 coupe 2004 auto.
I'm looking for a project in the near future, there's a few options I'm thinking of and one of them is engine swapping my v35...
I want to slap another nissan engine in !
I thought a vk45 or a vq30det would be cool.. and yes I know they will be huge projects but that's why they're called projects... I got a few thousand to play with but not moon money if that makes sense !
Any ideas/help/ advice on either would be appreciated !
Cheers team
https://www.sau.com.au/forums/topic/480883-v35-coupe-engine-swap/
VQ30DET makes no sense. 1. It's older, so you won't get it legal. 2. It's just another bloody VQ engine. Better off just slapping turbos onto the VQ35 you have.
VK makes sense, because V6s are gross, and V8s are not. You should work out the max capacity you can have by the NCOP rules and see if you shouldn't be planning on the largest VK (the 56). I'd suggest it should be feasible, because you can drop LS engines into these things, and they are larger capacity.
If going V8, then smaller/lighter/better makes more sense. Smaller, lighter and better than the VK, I mean. That means LS. I would be looking for an LS2 or LS3 myself. All alloy, narrower, easier to fit. Remember that the VQ you have is a 60° engine. The VK is a 90° engine and its heads are quite wide.
Cheers mate ! True about the vq30 too... would like to see a vk45 more than an LS I think itll be more cool/different.
The number of thousands to do any project like this are in the realm of 10,000's, not 1,000's..
Sadly a V35 engine swap (what do you plan to do with the auto gearbox?) is really less feasible than getting something more suited to the task.
VK56 swaps have been done, but I believe they are extremely tight in that engine bay.
https://g35driver.com/forums/engine-drivetrain-forced-induction/455271-04-coupe-vk56-engine-swap-build-8.html
People tend to go the LS1 route though, easier, stronger, more upgrade options, availability of parts.
also seems like a lot of people start the vk** swap and never finish it as I couldn't find many running examples only one I've seen in person is the MCA 370z and that is never going to be a street car again.
If wanting V8 the LS* swap is the way, can even use the CD009 6 speed these days that way really should only need engine mounts. Other thing may be a honda 4 cylinder of some variety pending year to meet emissions but thats a small engine in a barge.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
