Thats pretty much exactly where my filter is on the race car, no issues so far, obviously the GTR has a pair of BOVs forward and below that would get hit first.
I also have my oil cooler thermostat block up and forward of that location. It's all still behind the reo but potentially a problem in a medium or larger front crash
Also, having it angled down like that really helps tidy oil changes, and access to that location is good without getting under the car
  • Like 1
4 hours ago, ActionDan said:
Awesome progress, well done.
Filter setup looks neat, not worried about it being damaged there?
Cheers, no issues with damage there as Duncan said it's out of the way in any major incident.
Yep exactly same reason I have the cooler on the back of the radiator for that just in case. The reason we angled it was to get the fitting work but great to know for changes.
Well made it to the dyno and all run in with a soft base setup.
Made 261kw and 450nm on 18psi.
Held it back as concerned about breaking the sr gearbox so Looking at the 350/370z gearbox conversion and a r35 coilpack setup as was breaking down at 20psi.
Got to now rebleed the brakes, adjust front camber washers as struggled getting tie down straps on, fit rear wheels and get an alignment.
Looking at 10th November for first outing at QR to shake it down and see what else needs sorting before committing to events next year.
  • Like 3
1 hour ago, Dose Pipe Sutututu said:
Looking very spicy, will be entertaining trying to hold it straight when it comes on haha
Right foot should be able to help a little, I am more concerned about the sr gearbox.
11 minutes ago, bcozican said:
💪 ducting looks good too
what coils setup ?
Cheers, currently old splitfires but looking at Taarks or PRP R35 kits.
Minister of finance has agreed to mods but need to sell my pinball machine to fund it. First world problems.
Edited by robbo_rb180
I missed the last bit, have you chosen between the pinball machine and the minister of finance yet?
Anyway, in your old thread you said "Also fitted and wired up a new oil pressure/temp sensor and sorted fuel pressure with the old oil pressure sensor now reading it. Got a cheap Android double din wired up and have the link data showing on real dash app. "
Can you expand on that? Are you using CAN2 inside the Link to one of the Seeedstudio adapters to the head unit USB? It's time for me to do something similar for the stagea as neither the Epson EJ1 nor the Nismo dash have stood the test of 3 decades....
Hey Duncan,
Yeah pinball machine is going to fund next mods. Good game to being a star wars premium.
I have the usb tuning cable running to the head unit then run realdash app
http://realdash.net/index.php
You can run it over CAN to a usb adapter the info is on the site. I have found it great to use once you get use to it and setup. If you want to get fancier and send messages over CAN if ecu can do it there is the toucan device
https://www.hawkemotorsport.co.uk/Store/jti-toucan-display
Thanks mate. Some of the doco is conflicting (or out of date), I understood the tuning cable was not an option for the G4X plugins and you had to use the USB adapter (or CAN to OBD2 to OBD2 bluetooth to head unit), good to know the cable is an option.
Do you run a USB splitter of some sort so you can still plug in easily?
I am still using g4+ so heaps simpler. G4X needs an adapter, needs to be run on can2 to the adapter. I'll see if I can find the adapter I bought to test with.
  • 3 weeks later...
Well test day finished up early......
Started day with power steer res being too full and sparying part of the bay, bonnet and windscreen. Car also felt really weird in the corners so adjusted rear Sway bar and dampners which helped the under steer but still moved around and heap.
The steering was feeling weird the whole time then one of the hoses stared leaking from the fitting at the rack so sorted that which was fun to do 😅
Got it sorted for a few passenger ride sessions but car still was weird moving around in the corners. Just thought should check the pressures as started at 24psi cold they weren't coming up so went 30psi and that sort of fixed this weird shimmying thing but steering felt off. Went for one more session and dropped a wheel in a corner and when it got back on the track heard a bang and lots of clunking 😪
Got it up on stands in the pits and found the diff making noises so called it there. Don't know if it's the gears or the centre yet.
So got a few decisions to make on whether to fix it or jump into the new car........
A quick video of the new cars interior, so much nicer than the 180sx. Now with few issues with the 180sx may be time to swap drive line over.
  • Like 1
It's called a test for a reason lol Shit breaks, fix repeat go fast etc.
Interior looks lovely :)
I have a soft spots for 180s vs Silvia's, so many times I have almost bought a 180 roller but I can't part with my shit heap.
  • Like 1
1 hour ago, bcozican said:
not got alot of luck there do you
new car interior really nice - wish they all stayed that way
Is it literally going to be everything from the 180 straight into the s15 or anything new?
Yeah this car has fought hard with this rebuild. Almost a sign to give up on it.
Yeah was going to swap engine and diff. Was going to upgrade box when came time to swap it.
S15 is pretty much good to go besides ecu and display, looms all there. Got evo brakes to go on. Suspension wise its mca golds, pedal box, multiple pick up points on subframes, flat sway bar conversion. Ex ipra car that was setup really well.
Yeah that's it. Just issue of no where to work on it now as shed won't be up until February now with the new builder and probably not setup properly with power and hoist til April.
Yeah it's a super nice car, love the way the 180sx is looking now but s15 chassis is so much better.
  • Like 1
Just now, ActionDan said:
Properly caged they are very similar, especially when you can run an S15 subframe in everything else.
I will not be tempted again...
Probably, be interesting to feel the difference as I could tell between the sil80 and s14 I had.
Well it will definitely be a roller by Xmas next year.
Jeebus, that's a long wait for the shed!
How are you doing all this work without a garage?! 😮
Some stuff happened and I can't legally say but got a new builder who has jumped in at short notice and fitted us in.
Not doing anything now but a mate was letting me use his shed to get it together and running.
  • Like 2
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
